Anti-dive
  • TexasKZ
  • TexasKZ's Avatar Topic Author
Anti-dive
27 Jan 2010 08:24
#344893
<object width="425" height="344"><param name="movie" value=" www.youtube.com/v/ojeq3iu4HrY&color1=0xb...player_embedded&fs=1 "> www.youtube.com/v/ojeq3iu4HrY&color1=0xb...player_embedded&fs=1 " type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="425" height="344">
WOW on a bunch of levels! :woohoo: :woohoo: :woohoo:
Right now I am most stoked about that anti-dive device. Does anybody have some better pics or drawings of it? Any experience with it?
  • TexasKZ
Re: Anti-dive
27 Jan 2010 08:26
#344894
I totally apologize for that afflicted you tube post. It works, but clearly I need some instruction. :blush:
Re: Anti-dive
27 Jan 2010 14:23
#344936
One way to post a YouTube video in an outgoing Kzr message is by copying its address while it's playing, and then pasting the address into the outgoing KZr message between tags:
Hope this makes sense.
Good Luck! :)
Re: Anti-dive
27 Jan 2010 14:34
#344941
Good Luck! :)
For example, the first video embedded in the outgoing KZr message would look like this:
Good Luck! :)
Re: Anti-dive
27 Jan 2010 14:37 - 27 Jan 2010 14:54
#344942
Testing to see if it works as described.
[youtube] www.youtube.com/v/ojeq3iu4HrY&color1=0xb...%3C/param%3E%3Cparam [/youtube]
Dadgummit --- Hate it when that happens! :pinch:
Will try again. :)
Same result. Seems like the youtube tags aren't working like they used to. :)
Again - - -
[youtube]
[/youtube]
Last edit: 27 Jan 2010 14:54 by Patton.
  • TexasKZ
Re: Anti-dive
27 Jan 2010 16:22
#344960
Thanks, Patton. If it will stick to my memory cells, I'll give that a try next time.
Any info on that anti-dive link? Looks like an early BMW device. I wonder how well it worked and how difficult it might be to fabricate?
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Anti-dive
27 Jan 2010 17:51
#344978
the early 80s suzukis used an anti dive system run off of front brake pressure,really sucked in my book.if you want antidive try switching out the 10w fork oil for 30-40 weight synthetic B)
