Bearings and races for a 1977 kz 650 b1
  • oldkaws4ever
  • oldkaws4ever's Avatar Topic Author
  • Have no regrets...... You only live once.
25 Jan 2010 19:59
#344580
Im upgrading the bike to tapered steering bearings and im having a hell of a time getting the lower race into the neck of the frame. The top one went in with no problems at all. Any ideas on what to use to drive it in? Thanks, jim
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Re: Bearings and races for a 1977 kz 650 b1
25 Jan 2010 20:10
#344584
You may find a piece of PCV large enough. Just be sure the race starts in evenly all the way around; if it gets cockeyed it will be a bear to even up. Ed
25 Jan 2010 20:22
#344587
If not already done, might help to keep part in freezer overnight and install while it's still "frozen."
Good Luck! :)
  • sr man
  • sr man's Avatar
  • Hawk
25 Jan 2010 20:46
#344591
The first set I got from go all balls the race broke when I installed. I made a fixture at work just for this. I then measured the stem and race and the machinist f up. So I called them and they sent me another one free of charge and had no probablms be sure to put stem in freezer and pvc should do the job fine
Untill the sun dont shine
1978 kz650sr with 1980 E Ltd moter and carbs
Dyna Electronic Ignition
Dyna 3 Ohm Coils
Dyna wires
Progressive Springs Front Springs and
- and Rear Springs/Shocks
Wichita Kansas
  • Galactica
  • Galactica's Avatar
25 Jan 2010 20:59
#344597
I just did my kz900 a week ago. You have to really take you time. Make sure you have the race even all the way around all the time. You can do this using a drift to drive it in if you use light tapping side to side and around in a circle. Another tip is to use some emery cloth to remove a small amount of material from the head. A SMALL amount. Freeze the race and heat the head.
77KZ1000
76 KZ900
  • MFolks
  • MFolks's Avatar
25 Jan 2010 21:48
#344600
On a bearing(any type)never apply pressure on the inner part,always the outer race,otherwise the bearing will be quickly ruined.
  • OuttaTime
  • OuttaTime's Avatar
26 Jan 2010 19:46
#344831
hey oldkaws4ever, i did tapered bearings recently and it worked perfectly. Get 12" long 11/16" dia rod threaded all the way + (2) nuts + (2) 2"OD washers, start cranking...and voila!
Ed W in Lafayette, IN
1978 KZ650 (SR wheels & discs, Wiseco, Web, Dyna S, V&H 4into1)
  • Kawickrice
  • Kawickrice's Avatar
26 Jan 2010 19:57
#344834
I used a block of wood to get it flush the used a wooden dowel to drive it the rest of the way in, I used the jaws of a large cresent wrench to get the lower bearing down on the stem
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • oldkaws4ever
26 Jan 2010 21:18 - 26 Jan 2010 21:19
#344845
i used the block of wood to get it flush then the wooden dowel and it went right into place. Thanks for the tips guys.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Last edit: 26 Jan 2010 21:19 by oldkaws4ever.
