78 kz 650 c2 back tire???????
  • coldkz
  • coldkz's Avatar Topic Author
24 Jan 2010 16:39
#344371
hi there i as building a 1978 kz 650 c2 stock aluminum rear wheel...what are my tire size options...i would like to go a little widder any suggestions ho big or wide can you go??? thanks
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: 78 kz 650 c2 back tire???????
24 Jan 2010 16:57
#344375
Welcome.
130 is the widest that will fit on a stock C2 back wheel.
I have had a 130 on for years, but am thinking of switching to a 120 as some say it handles better with the 120.
Plus that's what Kawi engineers thought too.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
24 Jan 2010 17:00
#344377
You can go up tp 130/90-18 if you modify or remove the stock chain guard, I ran that size for years on my KZ650C1, BUT I don't recommend it. I switched to 120/90-18 and found that the tire is much less deformed because it isn't squeezed on that narrow rim. So it retains a better profile and in my opinion works as well or better than the 130. I highly recommend the Pirelli Sport Demon tires! They're a bias tire with a modern, radial-like tread pattern and they work well on the KZ650. Ed
  • coldkz
24 Jan 2010 17:13
#344383
thanks guys could you go with a 120 80 18 a little shorter
24 Jan 2010 20:15
#344424
The 80 is a little shorter but your engine will run at a little higher RPM on the highway (assuming stock sprockets).
