kz900 chain and sprockets
- asevans
17 Jan 2010 21:02
Hi. ive got a kz900. My chain and rear sprocket are about shot. Im going to replace the stock probably original stuff. now i think the stock stuff 15/35 sprockets and 92 link chain which I researched on here. ive also know that people change the sizes for different reasons. are those the stock sizes and is best to stay with stock? Thanx
1976 kz900 Mostly stock
1978 Z1-R Project
1978 Z1-R Project
- Mcdroid
- Gone Kwackers
Re: kz900 chain and sprockets
18 Jan 2010 00:13
15/35 is stock for a US spec. KZ900A4/A5. Whether you change ratios will depend on what type of riding you do...highways miles vs. stoplight-to-stoplight miles.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Old Man Rock
18 Jan 2010 04:36
Here... Maybe this will help...
Stock 15/35 92 link pitch 630 chain = 2.33 gear ratio
Works this way:
You want a little added zipp "stop light to stop light, acceleration" either increase the rear or decrease the cc sprocket.
NOTE: There is a cost for that though, slight increase in rpm so more wear and tear on the engine, decreased gas mileage and a loss of top end speed...
You want more cruise Freeway, lower rpm, better gas mileage but you loose the zip factor...
As McDroid stated, depends on your riding preferences...
OMR
Works this way:
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- PLUMMEN
18 Jan 2010 08:40
and for heavens sake put some lock tite and countershaft sprocket nut when you install it! :laugh:
- Old Man Rock
18 Jan 2010 08:52
:laugh: :laugh: :laugh: You bastard!
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- asevans
18 Jan 2010 11:01
Ok Thanx. ill keep it stock. No reason to mess with stuff this time around. im reading the manual on how to do this. Im going to replace the drive sprocket the rear sprocket and the chain. is that all i need to buy. is there any advice on this project you guys can give me on doing this. looks like i need to remove the swing arm. looks like this will be a good opportunity to clean alot of stuff i normally cant get too. thanx for any advice.
1978 Z1-R Project
1978 Z1-R Project
- timebomb33
18 Jan 2010 13:43
no need to remove the swingarm unless you buy an endless chain, you know what they say work smart not harder
I THINK MY POWERBAND BROKE
- donthekawguy
21 Jan 2010 01:20
Getting the front sprocket off is a bitch but keep at it and it will come off. You might have to jam a hunk of wood in it to hold the sprocket so you can get the nut off. Also buy a new keeper thinggy that keeps the sprocket from coming loose.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- roy-b-boy-b
21 Jan 2010 09:57
Remove the front sprocket first thing. Put the bike in first gear and if it won't hold have someone hold the rear brake.
If it were me i would go with the smaller but as strong 530chain set up.
I bought mine from Jeff at Z1enterprises. They are a sponser of this site and great people to deal with. Roy
