stretching a 77 KZ1000 and front end swap
- spiky77KZ1k
04 Jan 2010 22:26
hi guys
i'm new to this site and been reading most topics ansd seems you guys can help me achieve my goal
just purchased a 77 KZ1000 and below is what i would like to do and need advice on.
how much of a stretch is long enough?6" or 8" or 10"
where can i buy a stretched swing arm that does not require much fabbing?
i would like to run new style sport bike wheels(17") front and rear with a 180 or 200mm tire, which do you recommend?
i want the new style upside down front end, which one will fit pretty easy with out much cuttung and welding??
does the steering neck/head have to cut and raked to be able to run Vance n Hines sidewinder headers?
gents any help and advise will be highly appreciated.
i just got the bike home last night , and i'm still out of the county working but will be home soon and want to dive right in to modifying my KZ,so any help i can get before getting home would be great it will save me alot of time and i can start purchasing parts and have em deliverd by the time i get home
thx, Spiky.
thx, Spiky.
Re: stretching a 77 KZ1000 and front end swap
05 Jan 2010 06:49
nice looking bike,welcome.
search the site for front end swap,or frontend conversion,and also for swingarm swap,or swingarm conversion.should get you the info you seek,
leon holmes
leon holmes
- camaroguy
05 Jan 2010 15:46
a friend of mine has a 81 gpz with a sidewinder pipe. I think his front end is from a zx7 or 9. does not interfere with tire.he did modify it past the collector to tuck tighter to the frame.
- PLUMMEN
05 Jan 2010 16:15
why do you want to extend rear of bike so far? normally 2-3 over on swingarm is enough to just about anything down on the street,start going too much over and the rear wheel wont have enough weight on it to hook up anything short of a turbo
- roy-b-boy-b
05 Jan 2010 18:26 - 05 Jan 2010 18:27
You could build your own. It is a pain.It took me about three hours to build the middle one. I run the one on the left. Roy
Last edit: 05 Jan 2010 18:27 by roy-b-boy-b.
- spiky77KZ1k
05 Jan 2010 22:20
thanks for the info i was thinking of going the route of building one, got a group of 5 friends that built their own and dropped em and they look super sweet
thx again.
thx again.
- spiky77KZ1k
05 Jan 2010 22:26
i was thinking of a max of 4" and to use modified rear suspension like my cousin has set up for his 1/4 bike.
- mark1122
- Keep twisting it
03 Feb 2010 15:31
are u going to drag race it?
just about any front end will work. they all require the same mods.only a few will alow the use of the speedo gear.
the 94 to 97 zx9 is the longest, that alows the speedo gear.that i know of. i used a 96.
a 2 ' over arm will keep the front end down. i have a 2" over zrx arm with a 1200cc motor.
Do u have fab skills, and equipt ?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Old Man Rock
03 Feb 2010 17:41
As mark queried, without some skills & tools this can get expensive...
Maybe this will help in what your looking at for these conversions... Note, you don't have to go the mono shock swing arm approach for there's other 2" over swing-arms available that take dual shocks....
ZX636 Front end:
kzrider.com/index.php?option=com_docman&...d&gid=431&Itemid=108
Zx6 Swing-arm:
kzrider.com/index.php?option=com_docman&...d&gid=430&Itemid=108
Good luck...
OMR
ZX636 Front end:
Zx6 Swing-arm:
Good luck...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- MFolks
03 Feb 2010 19:32
I could be wrong, but when the swing arm is stretched what does it do to the chain slop? I'd think without some tensioning roller, the chain would have periods where it's tight and loose as the rider went down the road.
04 Feb 2010 09:54
10" stretch? That thing will handle like a schoolbus :laugh:
