Mono shock?
  • nebiker51
  • nebiker51's Avatar Topic Author
Mono shock?
30 Dec 2009 10:36
#341199
I have to ask, having never owned a mono shock bike for dirt or road, what if any advantage to a mono over twin shocks? Can't be a big weight difference since the mono shock looks larger and whatever frame support that has to be added. Is it just a different look you're going for?:unsure:
77 KZ1000 LTD - original owner
79 650xs - street tracker project
91 HD FXLR Custom - original owner
  • testarossa
  • testarossa's Avatar
Re: Mono shock?
30 Dec 2009 11:01
#341201
I'd bet most on here do it for the look/cool custom factor. Allows a larger rear tire. Cheaper to upgrade. One Ohlins is cheaper than two. Allows for ride height adjustment with cheap dogbones. My $0.02.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • Locozuna
  • Locozuna's Avatar
Re: Mono shock?
30 Dec 2009 11:25
#341204
Gives the back end that new open look and shows off your new swing arm and fattie. Bling thing...
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Mono shock?
30 Dec 2009 11:57
#341207
Other than a fattie... :S it does provide finer tuning
in your suspension (height to ground (spring), damping, rebound, soft or hard etc...)based on load weight, road surfacing, riding styles etc...
Old kaw suspension, you had a few clicks on the rear shocks... Granted, all we had back then even on dirt bikes but compared to new... Naw there's a hell of a lot more than just looks....
Same time, you have a stock OEM setup, maybe air shocks, OEM engine build, don't ride like a raped ape just cruise and the dual rears will most likely just be fine.... ;)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Locozuna
  • Locozuna's Avatar
Re: Mono shock?
30 Dec 2009 13:20
#341219
Oh....You're comparing it to stock shocks. That is different. I have always heard stock shocks are bad if you roll it out of the factory. There are a few double shocks that I think compare to a single setup performance wise. I would also think of strength. A wide three point triangle seems to me to be stronger. I can see the swingarm upgrade it's lighter and stiffer but you need to upgrade the bearing and stiffen the frame to really see a difference there too. As for the fattie :huh: being better over the stock tire in performance that is an arguable point also. Unless it's for a drag bike I still think it's a blingy thingy. Not that that's a bad thingy. I like blingy too. (But not on my thingy). :S
X-Rated Version of this argument.
Hey you got blingy on my thingy!!
Well you got your thingy in my blingy!
With apologies to Reeses PB Cups.....
Honey, it's 15 degrees out can I go ride my bike now?
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
  • Old Man Rock
Re: Mono shock?
30 Dec 2009 13:34
#341222
:laugh: :laugh: :laugh: You kill me old man.
BTW, For the KZ1000, I'm staying with dual rear shocks...
Thinking air shocks is the way to go... Yes/No?
Thoughts anyone who has them...
Thanks,
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • testarossa
Re: Mono shock?
30 Dec 2009 21:08
#341306
+1 on the air shocks
This is the new bike that you will keep fairly stock for rides with the wife, no? No other system allows so much adjustment for preload. It would be trick if you could adapt a Goldwing setup.
2004 ZX-10R
Angola, IN
  • Old Man Rock
Re: Mono shock?
31 Dec 2009 06:29
#341351
"This is the new bike that you will keep fairly stock for rides with the wife, no?"...
Yup, staying stock as much as possible. No engine/cam/carb mods even. Goal is to keep it under $1K....
Thanks,
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
Re: Mono shock?
31 Dec 2009 07:03
#341361
Single rear shocks offer superior suspension qualities (think about the linkage). One can get wide rear tires and maintain the look of the twin rear shocks. There is no rigidity found in having two rear shocks out back as opposed to one up in the center...remember shocks are meant to smoothly track the rear over suspension irregularities, so if the rear shocks offered rigidity that would be counter productive to what one would want the rear to do.
"fatties"...you boys can't be left alone for a minute! :woohoo:
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
  • Locozuna
  • Locozuna's Avatar
Re: Mono shock?
31 Dec 2009 10:01
#341386
OMR
I don't do that anymore......
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
