Steering Head Tapered Roller Bearing Tutorial
  • Kawickrice
  • Kawickrice's Avatar Topic Author
30 Dec 2009 08:43 - 04 Feb 2010 18:38
#341185
I just changed out my steering head bearings and thought it would be nice to have a short tutorial on the process. The tapered roller bearings are the only way to go in my opinion. Once done you will never have to change them again. It will take a few hours to do if the front end needs to be disassembled, but is simple enough for the beginner to do. It is about safety so enjoy.
First I used a handle for a floor jack to remove the cups
Here is a pic of the tapered roller bearings. The larger one goes to the bottom.
The top one will end up being flush with the frame, and the bottom one will go all the way in until it stops I used a block of wood to get them in then I used a wooden dowel on the bottom to get it all the way in
Here is the bottom one driven all the way home
And the top one is flush
Removing the lower race from the stem
When you put the lower bearing on the stem it is tight, what I did was use a large crescent wrench and opened the jaws so I could catch the inside of the bearing then taped it on with a hammer. "DO NOT" use the outer part of the bearing while tapping with a hammer you will destroy the bearing
And finally the lower bearing installed on the stem with a liberal coat of grease, waiting to be installed into the frame.
All in all it took about 30 minutes to do. Keep in mind my bike was torn down to the frame at the time so it may take a little bit longer if you have to remove the fork tubes and all that is connected. It is well worth the money spent to know it is done and all is good when done. Good Luck[/quote]
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Last edit: 04 Feb 2010 18:38 by Kawickrice.
The following user(s) said Thank You: Mcdroid, sf4t7
  • Galactica
  • Galactica's Avatar
Re: Steering Head Tapered Roller Bearing Tutorial
30 Dec 2009 11:43
#341205
Thanks for the tutorial. Will be ordering the bearings soon, but may hold off installing them until I have the frame powder coated.
77KZ1000
76 KZ900
  • Old Man Rock
  • Old Man Rock's Avatar
30 Dec 2009 11:50
#341206
Outstanding.... Share the wealth of knowledge! B)
PDf this and stick it in the File Data Base... ;)
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Kawickrice
30 Dec 2009 13:16
#341218
OMR
And just how do I PDF this to add to the filebase?
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • Old Man Rock
30 Dec 2009 13:49
#341224
How about I do it for you and post it under your name.... ;) Probably easier than trying to explain it.... :P :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • Old Man Rock
30 Dec 2009 14:00
#341225
All done... ;)
File database: Non Specific...
kzrider.com/index.php?option=com_docman&...d&gid=459&Itemid=108
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • Kawickrice
30 Dec 2009 15:16
#341238
Thanks Rock
You da man :) :)
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • Beto Trive
  • Beto Trive's Avatar
09 Oct 2026 17:05
#928402
Hola Arroz.
Soy Beto de Argentina.
Me podrias decir que rodamientos comprar? Resulta que busco como KZ650 y no encuentro nada de rodamientos para la dirección.
Muchas gracias!
Saludos!
