Fuel tank capacity
- savedrider
- 1975 Z1-B 900
Fuel tank capacity
22 Dec 2009 16:51
Someone please remind me again about how much fuel a '75 Z1 tank holds?
Thanks
Thanks
Get right or get left! <*{{{><
- Mcdroid
- Gone Kwackers
Re: Fuel tank capacity
22 Dec 2009 18:20
4.5 gal...or 17 liters
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- RonKZ650
22 Dec 2009 18:26
Remember though, that's a "new" tank. As most Z1s have been repainted, capacity could be anywhere from 1 to 4.5 gallons depending on the bodywork done.
- Galactica
22 Dec 2009 19:17
Also bear in mind two liters remain on the right side of the frame tube hump after the reserve is used. In order to access this fuel, you have to remove the tank and tip it over to the left, or lay the bike down on it's left side to spill the fuel to the petcock. So in essence you only have 15 liters of fuel.
77KZ1000
76 KZ900
76 KZ900
- savedrider
- 1975 Z1-B 900
22 Dec 2009 21:20
Thanks guys!
I'll just figure 4 gallons and do my math from there.
- Locozuna
23 Dec 2009 05:40
Galactica wrote:
You're joking right?
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- Bluemeanie
23 Dec 2009 06:49
Locozuna wrote:
Not really. Years ago I ran out of gas and had to push my bike aboiut 1/2 mile to the next gas station. I was getting really tired pushing that 465Ib bike . Just for the hell of it I tried starting it and it started! I hopped on and was able to ride it to the next station. I figured out that while I was pushing the bike it was leaning at an angle towards me and fuel was draining to the left side allowing enough gas to start and run. So yes, some gas remains on the right side when the left side runs empty!
Galactica wrote:Also bear in mind two liters remain on the right side of the frame tube hump after the reserve is used. In order to access this fuel, you have to remove the tank and tip it over to the left, or lay the bike down on it's left side to spill the fuel to the petcock. So in essence you only have 15 liters of fuel.
- Kawickrice
23 Dec 2009 06:56
I find it hard to run out of gas and push my bike since it is equiped with a reserve fuel system. Hitting reserve is one thing but hitting empty after reserve is another.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Galactica
23 Dec 2009 17:49
I'm not joking!! Just look at the construction of the tank. If it is sitting level, how is it possible for the fuel able to hop over the frame tube hump? I have filled up the dry tank on my 76 kz900. Sitting level, and filled to the top, it takes 17 liters. It takes 14 liters to hit reserve. One more liter until the reserve runs out of the petcock. Then I removed the tank, tipped it over to get the remaining fuel over to the petcock. Then I drained it into a measuring cup thru the petcock. 2 liters and the tank was then dry. So if you are riding along and run out of your reserve, just tip over the tank (there is usually enough play on the fuel lines), and you have 2 more liters of fuel. No joke!!
77KZ1000
76 KZ900
76 KZ900
- JR
24 Dec 2009 18:35
Makes sense to me. Really good information to have. I have come very close to running empty on reserve. There's not always a gas station around the next corner.
Thanks Galactica
Thanks Galactica
- Locozuna
24 Dec 2009 18:53
Wow! I have to admit I didn't think there was that much of a tunnel at the back end of the tank. Thanks!
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
