buying a tumbler any suggestions
  • thompsonmx100
  • thompsonmx100's Avatar Topic Author
11 Dec 2009 16:26
#338560
I am thinking about buying a tumbler this weekend any suggestions on what media to use. I'm gonna be doing the nuts and bolts on bike I'm thinking of going with the walnut shells.Thanks in advance.
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
  • fixer5000
  • fixer5000's Avatar
Re: buying a tumbler any suggestions
11 Dec 2009 16:30
#338564
walnut shells will take of corrosion but no metal at all
1978 kz650b pretty much stock
massachusetts
  • thompsonmx100
11 Dec 2009 16:39
#338565
will they remove paint and shine them up
1985 gpz750
Kz 650
  • Kawickrice
  • Kawickrice's Avatar
11 Dec 2009 17:35
#338572
I was just at harbour freight today to buy a bag of soda for soda blasting and saw the tumblers there. They had some triangle shaped media that was for the tumblers, but I do not remember what type of media it was.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • thompsonmx100
11 Dec 2009 17:48
#338574
Thats where I plan on buying mine. I was there before getting glass bead and I've seen that stuff too. I believe its ceramic. I think they also have it in plastic. Don't know how it works. Looks awfully course.
1985 gpz750
Kz 650
  • PLUMMEN
  • PLUMMEN's Avatar
11 Dec 2009 19:02
#338576
check eastwood.com B)
  • dshelly
  • dshelly's Avatar
12 Dec 2009 07:41
#338610
I tumble a lot of machined parts in my shop. Mostly new stuff, aluminum and stainless. For aluminum I use a green plastic media. For stainless I use ceramic. I order both of these online from www.candmtopline.com .
The plastic leaves a sort of galvanized look. Great for anodizing afterwards. The ceramic is more abrasive and will actually take off metal if you leave it in long enough. I know that walnut shells work good at polishing ,you can also add a red rouge to help take off shap edges. However walnut shells are very slow to work. You might have to leave your parts in for up to 48hrs.
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
  • otakar
  • otakar's Avatar
12 Dec 2009 11:02
#338630
I have been tumbling for years. Treated walnut shells are fine for Brass, aluminum and other soft metals. If you nead to remove rust and paint from steel. I use this.
www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93832
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • thompsonmx100
12 Dec 2009 14:07
#338646
Otakar that is what I ended up getting. Its says its a resin I have a batch in there already I figure I want to polish them I can go back with walnut shells.
1985 gpz750
Kz 650
  • otakar
  • otakar's Avatar
12 Dec 2009 15:17
#338659
It can take from 1-3 days to polish them and I think you will find that once they are done, your Nuts will shine. :woohoo: :laugh:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
