Tank mounting tab strength?
  • polkat
  • polkat's Avatar Topic Author
11 Dec 2009 14:24 - 11 Dec 2009 14:27
#338542
Like most older KZ's, mine has a tab welded to the back of the frame backbone for bolting down the back of the gas tank.
Would this tab be strong enough to also hold the front hinge of a solo seat? Like this....
Last edit: 11 Dec 2009 14:27 by polkat.
  • MFolks
  • MFolks's Avatar
Re: Tank mounting tab strength?
11 Dec 2009 15:30
#338555
I'd think if you made a doubler with additional bracing, then it might work.
  • thompsonmx100
  • thompsonmx100's Avatar
11 Dec 2009 16:15
#338558
I too would probably just strengthen it up some either some more plate and tie it into the frame some more or some tubing and tie it in.
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
