Finding these frame/tubing clamps?
- polkat
10 Dec 2009 20:54 - 10 Dec 2009 20:56
Below is a picture of a standard tubing clamp used with pipe. conduit, tubing, etc. I have been trying to find heavy duty versions at around 1 inch and thought they would be easy to find. Apparently not so. I've looked at OSH, True Value, and others without luck. Anyone seen these anywhere? Thanks!
Last edit: 10 Dec 2009 20:56 by polkat.
- MFolks
Re: Finding these frame/tubing clamps?
10 Dec 2009 21:19
Try these websites:
1. www.delcity.net
2. www.digikey.com
3. www.waytekwire.com
4. www.alliedelec.com
5. www.mouser.com
6. www.terminalsupplyco.com
7. www.terminaltown.com
8. www.electerm.com
9. www.wiringproducts.com
Look for heavy duty cushioned or uncushioned cable clamps.
1. www.delcity.net
2. www.digikey.com
5. www.mouser.com
8. www.electerm.com
- krazinite2003
11 Dec 2009 07:02
look at any store that sells semi truck parts
i have two 1983 kz750 L3
- TerryK
11 Dec 2009 07:13
krazinite2003 wrote:
That or an electrical supply store.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
11 Dec 2009 07:15
Might try JCWhitney, or check with local Harley dealership.
Good Luck!
Good Luck!
- TerryK
11 Dec 2009 07:17
Patton wrote:
A Harley part??? Blasphemy! :laugh:
Good Luck!
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
11 Dec 2009 07:41 - 11 Dec 2009 07:42
TerryK wrote:
:lol: :lol: :lol:
For whatever needs adding (and the faithful think that's really a lot), they'll also sell 'em a clamp to hang it on with. :laugh:
Good Luck!
...A Harley part??? Blasphemy! :laugh:
:lol: :lol: :lol:
Good Luck!
Last edit: 11 Dec 2009 07:42 by Patton.
- PLUMMEN
11 Dec 2009 10:01
are those the steel clamps with plasic coating on them? id try a heavy truck supply place
- Black KZ1000
- 1978 KZ1000,1974 bmw R90/6, 1977 xt 500 flattrcker
11 Dec 2009 16:28
We use something identical at work but with a rubber sleeve of sorts, they are called Adelman clamps.
- thompsonmx100
11 Dec 2009 16:29
yes sir try your local Mack truck dealer we used them things on everything. Alot of ours are rubber coated steel.
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- Black KZ1000
11 Dec 2009 19:22
So you need approximatly 1 inch clamps? How many? Let me see what I can do.
- polkat
11 Dec 2009 20:34 - 11 Dec 2009 20:37
Yes, I think it's 1", but I'll measure tomorrow to be sure. I need the all steel ones, not the rubber covered ones, and with the steel as thick as I can find. I only need 4, well, I'll say 5 in case one gets messed up. If you have some,PM me with a price. Thanks!
Last edit: 11 Dec 2009 20:37 by polkat.
