Finding these frame/tubing clamps?
  • polkat
  • polkat's Avatar Topic Author
10 Dec 2009 20:54 - 10 Dec 2009 20:56
#338472
Below is a picture of a standard tubing clamp used with pipe. conduit, tubing, etc. I have been trying to find heavy duty versions at around 1 inch and thought they would be easy to find. Apparently not so. I've looked at OSH, True Value, and others without luck. Anyone seen these anywhere? Thanks!
Last edit: 10 Dec 2009 20:56 by polkat.
  • MFolks
  • MFolks's Avatar
Re: Finding these frame/tubing clamps?
10 Dec 2009 21:19
#338473
  • krazinite2003
  • krazinite2003's Avatar
11 Dec 2009 07:02
#338492
look at any store that sells semi truck parts
i have two 1983 kz750 L3
  • TerryK
  • TerryK's Avatar
11 Dec 2009 07:13
#338494
That or an electrical supply store.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
11 Dec 2009 07:15
#338495
Might try JCWhitney, or check with local Harley dealership.
Good Luck! :)
  • TerryK
  • TerryK's Avatar
11 Dec 2009 07:17
#338496
Good Luck! :)
A Harley part??? Blasphemy! :laugh:
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
11 Dec 2009 07:41 - 11 Dec 2009 07:42
#338503
TerryK wrote:
...A Harley part??? Blasphemy! :laugh:
:lol: :lol: :lol:
For whatever needs adding (and the faithful think that's really a lot), they'll also sell 'em a clamp to hang it on with. :laugh:
Good Luck! :)
Last edit: 11 Dec 2009 07:42 by Patton.
  • PLUMMEN
  • PLUMMEN's Avatar
11 Dec 2009 10:01
#338516
are those the steel clamps with plasic coating on them? id try a heavy truck supply place B)
  • Black KZ1000
  • Black KZ1000's Avatar
  • 1978 KZ1000,1974 bmw R90/6, 1977 xt 500 flattrcker
11 Dec 2009 16:28
#338561
We use something identical at work but with a rubber sleeve of sorts, they are called Adelman clamps.
  • thompsonmx100
  • thompsonmx100's Avatar
11 Dec 2009 16:29
#338562
yes sir try your local Mack truck dealer we used them things on everything. Alot of ours are rubber coated steel.
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
  • Black KZ1000
11 Dec 2009 19:22
#338579
So you need approximatly 1 inch clamps? How many? Let me see what I can do.
  • polkat
11 Dec 2009 20:34 - 11 Dec 2009 20:37
#338584
Yes, I think it's 1", but I'll measure tomorrow to be sure. I need the all steel ones, not the rubber covered ones, and with the steel as thick as I can find. I only need 4, well, I'll say 5 in case one gets messed up. If you have some,PM me with a price. Thanks!
Last edit: 11 Dec 2009 20:37 by polkat.
