Strut mounting hole...thick enough?
  • polkat
  • polkat's Avatar Topic Author
04 Dec 2009 17:43 - 04 Dec 2009 17:44
#337545
I had a shop make me up some struts for the back of my KZ750. They made them from 1-1/2" by 3/4" mild steel bar. I noticed after I picked them up that the bottom (swingarm) hole is sort of near the end of the bar, with about 3/16" steel at the end, like this...
I know that is more steel then is in most shock eyelets, but is that going to be strong enough? All that area has to do is lift up the wheel/swingarm if the frame gets higher off the road in a bounce, maybe 50lbs total on each bar. I think it will be fine. Anyone disagree?
Last edit: 04 Dec 2009 17:44 by polkat.
  • timebomb33
  • timebomb33's Avatar
Re: Strut mounting hole...thick enough?
04 Dec 2009 17:45
#337546
it should be fine look at the thickness of your lower shock mount it won't be much different
I THINK MY POWERBAND BROKE
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
04 Dec 2009 18:10
#337549
Agreed, seems fine to me.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • PLUMMEN
  • PLUMMEN's Avatar
05 Dec 2009 09:02
#337606
make sure you put enough radius on end of struts to mount them,and dont forget to stock up on preperation H ! :laugh:
