What is my speedo ratio?
- elcid
23 Mar 2006 10:56
I have a 79 KZ650 but I want to switch to a 16 inch rear wheel & a 19 inch front. So what would my speedo ratio be? Would it be the same for tach as well? Doesn't changing the wheel size change the ratio?
- wireman
Re: What is my speedo ratio?
23 Mar 2006 11:01
if your front wheel is already 19" it shouldnt affect it too much,thats where your speedometer runs from.tach is run off of motor tire size will not affect it.:whistle: goodluck,happy wrenching!
- elcid
- wireman
- elcid
23 Mar 2006 12:20
Ok well how do I know what speedo to get? Does anyone know what the ratio is?
- wireman
23 Mar 2006 12:28
you should be able to use a tach and speedo off a 650,900 0r thousand up to 1980 i believe.do ya need one?
- elcid
23 Mar 2006 12:33
Well actually I want to buy a completely different speedo/ tach for it. Something from JP Cycles for example. I just need to know what ratio to get. Does anyone here know this? Surely someone must have installed one of these on their KZ650 with a 19 inch front & 16 on back...
- hwms
23 Mar 2006 12:39
I would suggest that you contact some one like JP Cycles (?). Tell them the size wheel you will be running. They, most likely, can tell you what you need.
- elcid
23 Mar 2006 13:20
That is a good answer. I will just wait until I have the wheels I am using & then call them & ask. Thanx guys!
- wireman
23 Mar 2006 15:11
if you would have brought up the fact you want to install aftermarket gauges from the start that would have been very helpfull.no biggy;) goodluck,happy wrenching!
- Shoe48
- Live each day as it is your last
23 Mar 2006 15:26
You can figure it out by counting the turns of your tach cable to one turn of the engine ,, I know sounds kinda hard to do .. I ran into this with my Honda a few weeks ago ,, They sent what They thought I needed ,, it was a 1-7 tach I really needed a 1-5 tach ,, how does this work ? one turn of the tach cable , The tach will read 5 RPMs . one turn of the tach cable will read 7 rpms. as you go up the scale say 1000 turns of the tach cable 5000 on the tach so the difference between a 1-5 and a 1-7 ,, is ?? Well it multiplies as you go up the tach RPMS 1000 tach cable RPMS = 5000 1-5 , 1000 tach cable rpms 7000 1-7 so in the beginning it was only 2 rpm off but at the end it is 2000 rpm off ... I am so confused now ,, so I know you are too ...
- steell
23 Mar 2006 17:23
Try doing a search both here and in the Archives, I'm reasonably certain that I saw that info posted here in the past.
