Mulholand Rear Shocks
  • kenskz1000
  • kenskz1000's Avatar Topic Author
29 Nov 2009 10:27
#336484
I just bought a set of Mulholand's. Can the springs be taken off so I can have them powder coated? If so how? I want to clean them up for my 77 1000 LTD
  • loudhvx
  • loudhvx's Avatar
Re: Mulholand Rear Shocks
29 Nov 2009 10:54
#336491
Usually, you just compress the spring and the silver ring at the top will slide down slightly then slide off the shaft completely because it has a cutout in the ring.
I use a contraption I rigged up for compressing the spring, but you can buy them too. Sometimes, if the springs are soft enough, you can compress them enough by hand.
Either way, set the preload to the minimum setting before trying to remove it. It makes it much easier.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
29 Nov 2009 14:36 - 29 Nov 2009 14:37
#336546
i would mount them and try them out first.
are the eals still good?
The gas/oil, may have leaked out years ago?? make sure the springs are the right wieght by seting the sag . if u cannot get the proper sag level u will need new springs of a dif wieght.
good luck, have fun, keep it twisted.B)
Loudhvx, that compressor is great.B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 29 Nov 2009 14:37 by mark1122.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
29 Nov 2009 16:06 - 29 Nov 2009 16:06
#336572
I bought a set of spring compressors on ebay to do mine. $25 + shipping:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 29 Nov 2009 16:06 by rstnick.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
29 Nov 2009 17:05
#336601
B) B)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Locozuna
  • Locozuna's Avatar
29 Nov 2009 19:35
#336636
We cut a notch in an old lawnmower blade. One person slips it into the spring and presses down while the other person removes the clip. Pat. Pending :)
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • Bluemeanie
  • Bluemeanie's Avatar
30 Nov 2009 06:01
#336670
Hmmmmmm, a lawn mower blade that pops off under spring pressure and go flying around the room. Sounds interesting.... :blink:
  • Locozuna
  • Locozuna's Avatar
30 Nov 2009 06:42
#336674
Flying lawnmower blades does sound interesting! Maybe in the next Saw movie. ;) Truth is it's not too hard to compress the springs. I was a little surprised at first. At least on the Mulholand shocks. With both hands on the blade all you really have to do is make sure you have a stable base for the shock to sit in. Then put your weight to it. The other person just removes the clip and it's done. Same to reinstall the clip. If you keep both hands on the blade there is not much chance of a flying blade. Used it 3 or 4 times. Made the tool in about 2 minutes and used it for the same. Not for everyone and understand the apprehension. Blade sits there for 364.5 of the 365 days a year. I guess if I was a shop or did it more I could justify making a super duper spring compressor or buying one. If I was that concerned about it I guess I'd take it to a shop and slip the guy a couple bucks. Flying Lawnmower Blades Batman!!! ;) As Bluemeanie rightly points out it is not something to take for granted because it is dangerous. Anytime you have something compressed there is danger. Be careful with any compression device!!!
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
  • trianglelaguna
  • trianglelaguna's Avatar
30 Nov 2009 07:02
#336676
carl......i rekon ....mmmm...bisquits and mustard....
this is one more trick/tricks i've learned on this awesome kzr sight...thanks guys...always wondered about those magical cut outs and how a guy could access the springs and re-paint bodies and springs.....next???...what is the best coating that'l stick with the action they will be doing???
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • Locozuna
  • Locozuna's Avatar
30 Nov 2009 09:02
#336690
Don't like heating up springs so I'm not crazy on powder coating. Whatever you paint make sure the paint for the springs is not too brittle. The shock body is less of a problem.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
30 Nov 2009 11:46 - 03 Dec 2009 15:59
#336713
Actually, with due respect to loco, an old boomerang is better than a lawnmower blade, because if it flies loose, it just comes back. B)
Meanwhile, with spring preload set in lightest position, clamp shock upright with bottom eye in vise, use grip and arm strength to push down and compress the spring enough to remove the top retainer clip.
Can do it solo, but easier with an assistant. :cheer:
Good Luck! :)
[Click on image to enlarge view.]
Edited -- to add image and suggest using lightest spring preload setting.
Last edit: 03 Dec 2009 15:59 by Patton.
  • Locozuna
  • Locozuna's Avatar
30 Nov 2009 12:58
#336718
Meanwhile, clamp shock upright with bottom eye in vise, use grip and arm strength to push down and compress the spring enough to remove the top retainer clip.
Good Luck! :)
Nothing wrong with a better mousetrap. But if style counts (and it does) I suggest a baterang. Best part is it's right there in your utility belt when you need it.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
