Mulholand Rear Shocks
- kenskz1000
29 Nov 2009 10:27
I just bought a set of Mulholand's. Can the springs be taken off so I can have them powder coated? If so how? I want to clean them up for my 77 1000 LTD
- loudhvx
Re: Mulholand Rear Shocks
29 Nov 2009 10:54
Usually, you just compress the spring and the silver ring at the top will slide down slightly then slide off the shaft completely because it has a cutout in the ring.
I use a contraption I rigged up for compressing the spring, but you can buy them too. Sometimes, if the springs are soft enough, you can compress them enough by hand.
Either way, set the preload to the minimum setting before trying to remove it. It makes it much easier.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- mark1122
- Keep twisting it
29 Nov 2009 14:36 - 29 Nov 2009 14:37
i would mount them and try them out first.
are the eals still good?
The gas/oil, may have leaked out years ago?? make sure the springs are the right wieght by seting the sag . if u cannot get the proper sag level u will need new springs of a dif wieght.
good luck, have fun, keep it twisted.
Loudhvx, that compressor is great.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 29 Nov 2009 14:37 by mark1122.
- rstnick
29 Nov 2009 16:06 - 29 Nov 2009 16:06
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 29 Nov 2009 16:06 by rstnick.
- mark1122
- Keep twisting it
29 Nov 2009 17:05
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Locozuna
29 Nov 2009 19:35
We cut a notch in an old lawnmower blade. One person slips it into the spring and presses down while the other person removes the clip. Pat. Pending
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- Bluemeanie
30 Nov 2009 06:01
Locozuna wrote:
Hmmmmmm, a lawn mower blade that pops off under spring pressure and go flying around the room. Sounds interesting.... :blink:
- Locozuna
30 Nov 2009 06:42
Bluemeanie wrote:
Flying lawnmower blades does sound interesting! Maybe in the next Saw movie.
Truth is it's not too hard to compress the springs. I was a little surprised at first. At least on the Mulholand shocks. With both hands on the blade all you really have to do is make sure you have a stable base for the shock to sit in. Then put your weight to it. The other person just removes the clip and it's done. Same to reinstall the clip. If you keep both hands on the blade there is not much chance of a flying blade. Used it 3 or 4 times. Made the tool in about 2 minutes and used it for the same. Not for everyone and understand the apprehension. Blade sits there for 364.5 of the 365 days a year. I guess if I was a shop or did it more I could justify making a super duper spring compressor or buying one. If I was that concerned about it I guess I'd take it to a shop and slip the guy a couple bucks. Flying Lawnmower Blades Batman!!!
As Bluemeanie rightly points out it is not something to take for granted because it is dangerous. Anytime you have something compressed there is danger. Be careful with any compression device!!!
Locozuna wrote:We cut a notch in an old lawnmower blade. One person slips it into the spring and presses down while the other person removes the clip. Pat. Pending
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- trianglelaguna
30 Nov 2009 07:02
carl......i rekon ....mmmm...bisquits and mustard....
this is one more trick/tricks i've learned on this awesome kzr sight...thanks guys...always wondered about those magical cut outs and how a guy could access the springs and re-paint bodies and springs.....next???...what is the best coating that'l stick with the action they will be doing???
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- Locozuna
30 Nov 2009 09:02
Don't like heating up springs so I'm not crazy on powder coating. Whatever you paint make sure the paint for the springs is not too brittle. The shock body is less of a problem.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
30 Nov 2009 11:46 - 03 Dec 2009 15:59
Actually, with due respect to loco, an old boomerang is better than a lawnmower blade, because if it flies loose, it just comes back.
Meanwhile, with spring preload set in lightest position, clamp shock upright with bottom eye in vise, use grip and arm strength to push down and compress the spring enough to remove the top retainer clip.
Can do it solo, but easier with an assistant.
Good Luck!
[Click on image to enlarge view.]
Edited -- to add image and suggest using lightest spring preload setting.
Good Luck!
Last edit: 03 Dec 2009 15:59 by Patton.
- Locozuna
30 Nov 2009 12:58
Patton wrote:
Nothing wrong with a better mousetrap. But if style counts (and it does) I suggest a baterang. Best part is it's right there in your utility belt when you need it.
Meanwhile, clamp shock upright with bottom eye in vise, use grip and arm strength to push down and compress the spring enough to remove the top retainer clip.
Good Luck!
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
