Tool for safe caliper piston removal
  • Kawboy74
  • Kawboy74's Avatar Topic Author
27 Nov 2009 17:47
#336203
Lesson learned almost the hard way as piston removal can be difficult! Being warned about issues using compressed air to remove piston causes one to use caution but when 40 lbs of air doesn't work, go to 80 lbs. Positive results realized during piston flight past my eyebrows spawned research into better method needed.
I had a machinist friend fabricate this fitting from a large bolt, turning the thread down to fit the banjo bolt opening and then drilling and tapping for a grease fitting. Grease under pressure is a lot more controllable and results can be monitored during process and if piston is stuck, it is likely the bore and passages are a bit cruddy. The grease can easily be washed out during caliper cleaning possibly using a parts washer. I think that all 900 and 1000 calipers are using the same size banjo bolt so this should be common throughout the series and if not, make another to suit. It works great! See pictures showing fitting.
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: Tool for safe caliper piston removal
27 Nov 2009 17:51 - 27 Nov 2009 17:52
#336205
Compressed air works well, or too well as you found.
Wrapping the caliper in a rag as you pump air in will keep the piston from shooting across the room.
Good idea with the grease fitting.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 27 Nov 2009 17:52 by rstnick.
  • s3steve
  • s3steve's Avatar
28 Nov 2009 04:21
#336232
Also if your using compressed air make sure you put a piece of wood in place of the brake pad to prevent the piston from causing any damage to the caliper.
1973 Kawasaki Z1
1975 Kawasaki S3
2006 BMW R1200RT
  • Skyman
  • Skyman's Avatar
28 Nov 2009 18:15
#336356
Yep, compressed air works best--as long as you are aware of the danger and prepare for it. I also wrapped it in a rag to catch the missile...er...I mean...piston. ;)
I was surprised the first time I tried it how quickly, and how powerfully that thing shot out of the caliper.
West Linn, OR
  • lapeerray
  • lapeerray's Avatar
29 Nov 2009 05:18
#336424
"For every action there is an opposit and equal reaction" :ohmy: :lol:
78kz650b2, 2009 kawasaki 25 hp Oturn John Deere with a 62" cut I had to have it. It was green and was powered by KAWI...,78 yamaha golfcar, Gone but not forgoten 82 v65 magna, 89 1200 Vmax, 72 GS380GT mint with 2000m.grandfather baught brand new in 72
  • Old Man Rock
  • Old Man Rock's Avatar
29 Nov 2009 07:39
#336454
Right out of my ZX636 manual for the caliper re-build.... Compressed air and piece of wood.... No issues or flying bullets... ;)
I've seen it mentioned with the grease fittings and using grease itself to pop the piston...
Not sure I like that idea of pumping grease into the caliper body... Once completed, you'd have to surely get 100% of that out of there or possible fluid contamination would be highly probable....
Ah well, most likely I'm miss understanding once again... No biggy....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Kawboy74
29 Nov 2009 17:59
#336620
I figured that if the piston is stuck enough not to want to come out easily, that extensive bore surface - cleaning would be necessary. Grease will loosen up with most brake cleaners and if inner surface is needing some resurfacing the grease is the least of your worries. A little extra cleanup is worth the ability to watch the piston ease out.On to the next issue!
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
30 Nov 2009 05:14
#336666
One tip that was in classic motorcycle mechanics, if the piston is REALLY stuck, drill a large diameter hole in the piston, tap it and insert a bolt and jack the piston out. It destroys the piston, but the chances are it was in rough shape anyway...
