Shorter shocks?
- polkat
Shorter shocks?
26 Nov 2009 16:04
What stock shocks from other bikes can I mount on my KZ750H that are shorter then the stock KZ750 ones (maybe by 2")? I can't afford custom shortening, but could probably find a good set of used stock somewhere.
- kano
- Not Another Bloody Limey!
- polkat
- kano
Re: Shorter shocks?
26 Nov 2009 17:48 - 26 Nov 2009 19:09
Last edit: 26 Nov 2009 19:09 by kano.
- JMKZHI
Re: Shorter shocks?
26 Nov 2009 19:41 - 26 Nov 2009 19:42
According to someone here (Andy the Gringo maybe?), Vulcan 500 shocks are shorter than stock & are a direct bolt-on. I believe the 750Ltd shocks are ~13.5" eye-to-eye. The Vulcans are somewhere around 11-12" eye-to-eye. Or...
You might be able to use HD Sportster shocks - lowering or huggers (the stock Sportys are ~13.25 eye-to-eye). The bushings & dampers will have to be swapped (no big deal). The bottom mount on them is wider than the KZ's, so you'd have to grind them down ~4mm or spread the swingarm mount open a tad. Also, if you keep the stock chrome chain guard, the Sportys will be very close & may rub it.
Last edit: 26 Nov 2009 19:42 by JMKZHI.
- The Gringo
- ¡Usted no necesita otra motocicleta!
Re: Shorter shocks?
26 Nov 2009 21:32
JMKZHI wrote:
Yep that's one of my favorite mods to do to a KZ since I'm a bit short in the inseam. Any of the Vulcan shocks 500/750 etc will bolt right on. The 750's are air adjustable and have adjustments for the dampning as well but they tend to fetch a bit more on ebay than the 500 Vulcan shocks do. IIRC I paid like $30.00 for one set and $40.00 for the other set.
Here is a pic of the 500 Vulcan shocks mounted on one of my 650's.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- polkat
Re: Shorter shocks?
26 Nov 2009 21:49
Hummm...may be the angle of the pic, but you're bike pic doesn't really look any lower to me. How much lower is it then with the stock KZ shocks? And is there a specific year Vulcan 500 shock to look for?
