bracing help
  • mark1122
  • Topic Author
  • Keep twisting it
25 Nov 2009 07:19 #335840 by mark1122
bracing help was created by mark1122
i am looking for someone to make a brace for me.
i would like to take my bike apart 1 more time.
i have found that i have a weave in the frame when i go around a bend very fast. I have a lot of work done to this bike , and i suspect that it could be the fact that i have less trail now.
It stands to reason that the new bikes get away with less trail due to there ridgide frames.
By adding more bracing, i may, or may not not help this. Just the same, i feel i want to take 1 last kick at this. If it still weaves, thats fine, it's not really a big deal. I will feel that i have done all that i can do though.
So what i need is the 2 braces that are shown in the Santuary PDF.
Located Here:
kzrider.com/index.php?option=com_docman&...w&gid=231&Itemid=108
look at the_frame PDF (15th from top)
Look at #4 in the PDF . I need the 2 frame rail piece below #4.
can anyone make me these?
does anyone have an old frame they can cut these rails out of and sell them to me??
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
25 Nov 2009 07:27 #335841 by PLUMMEN
Replied by PLUMMEN on topic bracing help
cutting them out of an old frame wouldnt work theyd be same diameter as your existing pieces ,you warp the hell out of em to stretch them around existing tubes.have you ever had that frame on a jig to make sure its straight? B)
  • mark1122
  • Topic Author
  • Keep twisting it
25 Nov 2009 07:39 #335846 by mark1122
Replied by mark1122 on topic bracing help
Thats a good point. not being a welder, i thought it might work .
Thanks.
no i have never had the frame checked for true. why do u ask?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
25 Nov 2009 08:12 #335849 by PLUMMEN
sometimes being a little crooked isnt noticable at low speeds,but at higher speeds things tend to be more obvious.these old kaw frames are mass produced with what id call close enough construction at best,when you start welding things on them it can make it worse as frame gets pulled in differant directions. B)
  • mark1122
  • Topic Author
  • Keep twisting it
25 Nov 2009 09:13 - 02 Dec 2009 14:16 #335856 by mark1122
At max rpm, 5th gear it rides true and smooth.No steering damper.
its just at lean with speed.
i can feel it twitch when u move on the seat .Trail,?
i don't feel that it can ever be flex free at lean.
I think that this is just the way it is for 30 yr old frames.
they have made a lot of advancements over the years, mono shocks,and ridge-ad frames, have allowed for a lot less rake and trail. now i have reduced the rake and trail without the rest of the modern frame upgrades.so it stands to reason that i will experience weave.
i agree with u 100% that the frame should be true to start with.
I'm just to cheap to bother having it checked, since i feel it probably ok. i feel it rides good enough now.
I just want to do all the bracing i can, before i repaint the frame.
can u give me anymore incite on welding these on the frame? am i at much risk of warpage if done by a professional welder?
Did u consider these for your frame?
i think i have all the same bracing as u so far, i just need to add the 2 rails from the neck down to the front rails.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 02 Dec 2009 14:16 by mark1122.
  • mark1122
  • Topic Author
  • Keep twisting it
25 Nov 2009 09:35 #335858 by mark1122
here is a resent pic. the welding needs to be cleaned up a bit. i also have the brace in front of the seat , ontop of the rails now.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
25 Nov 2009 16:10 #335914 by dutchz
Replied by dutchz on topic bracing help
Hey Mark, I've done them on my frame. Professional welder should be able to do this no problem. Making the bend and doing the fish mouthing was more work then the welding (a buddy did the welding). Tacked both sides on first and welded short sections moving from one side over to the next as not to put too much heat in one spot. Here's a pic of the whole chassis and some detail shots of the neck.
1974 Kawasaki Z1
Stock front hub and rear axle.
25 Nov 2009 16:11 #335915 by dutchz
close up r
1974 Kawasaki Z1
25 Nov 2009 16:11 #335916 by dutchz
close up l
1974 Kawasaki Z1
25 Nov 2009 16:22 #335920 by zippy
Replied by zippy on topic bracing help
Might want to think about picking up a Kosman frame brace kit and heavy duty motor mounts if they have them in stock. Here is the web site.
www.kosman.net/page12.htm#fbk
I have the frame brace kit and a set of AVS motor mounts and they made a HUGE difference.
  • mark1122
  • Topic Author
  • Keep twisting it
25 Nov 2009 16:25 #335922 by mark1122
on the front lower rails , yours look straight. i noticed that Sanctuary put a bend at the top of theirs. Why do u think they made the bend? why did u make yours straight?
are u going to add the 1's i'm looking for?
Do u have a weave at high speed lean?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • mark1122
  • Topic Author
  • Keep twisting it
25 Nov 2009 16:35 #335925 by mark1122
I have all of that now.
Thanks
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
