KZ FRONT END GSXR WHEEL??
  • dragnkaw1428
  • dragnkaw1428's Avatar Topic Author
24 Nov 2009 21:43
#335783
Does anyone know if its possible to run a front wheel of a 90-92 GSXR1100 on a 77 KZ1000 with all the stock KZ front end parts triple trees, forks etc. Lets hear some opinions and some knowledge.
Andy
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: KZ FRONT END GSXR WHEEL??
25 Nov 2009 04:58
#335817
I'm pretty sure the Kz front end isn't going to be wide enough to slot it right in. I'm running a Kz1000C police frontend, which is wider than a normal Kz, so I can run a 17x3.5" rim. Rivman has put a newer sportbike rim in stock Kz forks but it took ALOT of machining. You might be able to find a rim from a GS500, that is styled like the bigger rims, but is narrower through the hub.
Summary: You can make it fit but it'd be cheaper/easier to find another rim/frontend.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
25 Nov 2009 06:49
#335839
The 19" kz tire is about 27" tall, and a 17" is about 24".
u will have to find a way to lower the fender.
i had a 110 19" tire on my kz forks. it was tight due to the fender bolts.
remember,that if u go 17", u need 1 with a speedo gear, if u want to reuse your speedo. a zrx,zx9 have 1.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
