first time wheel bearing change
- jswag5
- whats the big deal about harley, i prefer 4 cyls!!
23 Nov 2009 15:41
on my way to work this morning i developed a slight wobbly sloshy feeling from the front end, along with a metallic squeaky sound. turning the wheel by hand on the center stand noticed dragging, so i think its a wheel bearing.
15 dollars later i have a set of bearings so now the question
this seems to be a fairly straight forward thing, freeze the bearings, heat the rim and drop the bearing in(tapping lightly if needed), is there anything else i need to know when doing this so i dont mess anything else up???
82 kz1000p
83 yammie xj750mk bobber
78 honda cx500 standard cafe
RECENT 81 honda goldwing(barn fresh with 15000 on the clock)
if you cant fix it with a hammer and duct tape, get a bigger hammer and more duct tape!!
- Kawickrice
Re: first time wheel bearing change
23 Nov 2009 16:23
That will probably be the thing to do. I usually do things the hard way without heat or cold, then finess them in being careful not to do damage anything.
Those cops sure put alot of miles on those bikes. I havent heard a squeaky bearing since one went out on my Chevelle a few years back.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- MFolks
23 Nov 2009 16:46
Are you going to use a propane torch or heat gun for the heating? I'd suggest keep moving the heat source around where the bearing will install without concentrating it too long in one spot.
- jswag5
23 Nov 2009 17:07 - 23 Nov 2009 17:08
prolly use a salamander box(large wooden box with a hole cut in it to shove forced heat into) i use when working on car rear ends and such, get the whole rim to a few hundred degrees
82 kz1000p
Last edit: 23 Nov 2009 17:08 by jswag5.
23 Nov 2009 17:38
Heating / freezing? It's your bike, but it sounds like overkill to me. I simply clean the mating surfaces well, put a very thin film of grease on them, and use a piece of PVC to GENTLY tappa tappa tappa the outer race into the wheel and 1 minute later I'm done. Mine have always gone in with minimal effort - no muss / no fuss and no cooking the original paint off the wheels. Ed
- jswag5
25 Nov 2009 19:00
froze the bearings and tapped with a socket and they dropped right in, but now the thing wont start, think something got rattled riding in the back of my truck. thats the first time since ive owned it that it got to travel without being the transportation. its weird, it starts off a jump pack and runs, but the instant i take the jumper off it dies, thinking this 6 month old battery dumped on me.
82 kz1000p
- MFolks
25 Nov 2009 19:26
If possible, fully charge the battery and have it load tested at a motorcycle shop.
Check the ground cable from the negative battery connection to the engine mounting bolt.Also look at the positive connections for signs of corrosion or looseness.
- jswag5
27 Nov 2009 15:57
battery was toasted, lucky it was still under warranty, so i got an exchange and was back on the road today.
bearings feel good and rides nice, the bearings were an easy fix, wont have any hesitation when i have to replace the rear(i know they probably wont last much longer)
82 kz1000p
- PLUMMEN
27 Nov 2009 17:41
bike shouldnt need battery to keep running once its started should it?
- MFolks
27 Nov 2009 17:52
My understanding on these older bike's batteries is that it acts like a surge tank, absorbing excess voltages and supplying them when a low charging situation happens(like at low rpm).
I'd think with the battery out of circuit after the bike is started,that the light bulbs may have shortened lives also possibly damaging the ignition and charging systems.
- jswag5
29 Nov 2009 08:46
do you think maybe i have a low charge issue as well, i hope not, this bike is turning into a money pit and i havent done any body or paint work yet.
82 kz1000p
