Lowering a KZ550?
- Tbird232ci
Lowering a KZ550?
21 Nov 2009 17:08
I was standing back, and looking at my bike, and realized that it has a MASSIVE fender gap in my eyes.
I figured that in the rear, unbolt the stocks, toss a jack under it, get the desired height, measure shock mounting points and order the shocks at that length. Am I correct at that point?
What about the front? I'd never want to cut springs or anything in the forks.
- Kawickrice
Re: Lowering a KZ550?
21 Nov 2009 17:29
The front you can probably drop the tubes down in the triple trees. On the back either buy shorter shocks or make some struts. The kickstand may need some tweaking other wise the bike is almost straight up with the side stand down and the wind can blow it over. Ask me how I know that.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
21 Nov 2009 22:35
Tbird232ci wrote:
Usually some wiring runs underneath the rear fender.
Would consider that excessive reduction in the gap between tire and fender may result in tire contact with fender and ripping out the wiring. Not to mention the abrupt jolt as the suspension prematurely bottoms out.
When measuring, would assure that fully collapsed shock remains long enough to allow some minimal gap between tire and underside of fender.
May leave front forks alone in their existing position inside the clamps (fork caps barely exposed). Lowering only the rear-end usually produces slower steering (more stable at speed), but with less flickability for cornering.
Good Luck!
Good Luck!
- polkat
21 Nov 2009 23:16
I lowered the stock shocks on my KZ750 all the way down and don't have any problems with the ride, but it's not as low as I would like it. Installing struts gives the same ride as a hard tail, so you might want to consider a well sprung seat if you go that way.
- JMKZHI
22 Nov 2009 06:18
Did you try checking it while sitting on the bike?
Vulcan 500 shocks are a direct bolt-on (info by Andy the Gringo?) - they're somewhere around 11-12" long eye-to-eye - I don't recall. You might be able to raise the tubes in the triple tree a tad to lower the front, but maybe not as much as you can lower the rear.
How does the bike handle in its current configuration?
