Tapered Neck bearing ? need answer asap
  • GregZ
  • GregZ's Avatar Topic Author
18 Nov 2009 05:55
#334443
Although I installed these bearings before I am cunfused a little.The bottom race when installed ,does it sit flush with the bottom of the steering neck( as shown) or do I seat it all the in. Or do I have the wrong bearing kit.
Thanks in advance
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: Tapered Neck bearing ? need answer asap
18 Nov 2009 06:15
#334445
Hi Greg,
You should drive it all the way home.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • loudhvx
  • loudhvx's Avatar
18 Nov 2009 06:39 - 18 Nov 2009 06:42
#334449
Normally, you would drive it all the way in til it seats on the inner ridge. But if you suspect the bearing will sit in too far, you may want to assemble it loosely, as is, to see if the yoke will interfere with the frame. If it does, there is a chance you have the wrong kit somehow.
You'll want to check before you drive it. Once the gap is closed up, you can't get a drift in there to hammer the race out. It's a bitch to get out after that. You have to dremel it out, or weld something to it to hammer on.
Last edit: 18 Nov 2009 06:42 by loudhvx.
  • timebomb33
  • timebomb33's Avatar
18 Nov 2009 07:31
#334452
drive it in all the way that's why that step is there if you dont it will pull itself together when you install the trees and you will end up crushing the bearings from the presssure it takes to pull them together.
I THINK MY POWERBAND BROKE
  • GregZ
18 Nov 2009 07:44
#334454
I seated it, now it's all back together looks ,feels good
thanks
  • WABBMW
  • WABBMW's Avatar
  • Let The Good Times Roll !
18 Nov 2009 14:33
#334502
Repeating what others have said, the tapered bearing race needs to be driven all the way into the seat. After doing this, I believe the remaining space on the small end of the race is for the grease seal to fit into. The tapered roller bearings are nice. Enjoy !
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
