Replace this fork valve?
- polkat
16 Nov 2009 18:39
Still rebuilding the forks on my '82 KZ750H. At the top of the internal pistons I found this black plastic valve.
It doesn't appear to badly worn, but is worn shiny on the external sides. Should these be replaced?
- JMKZHI
Re: Replace this fork valve?
17 Nov 2009 06:12
I think that's just some sort of spacer. Since it's not listed as a separate part, it might not be available. I just leave it be when doing forks - an old plastic part like that might be fragile & I'd rather not break it. The ones on the CSR are different & just look like a C-clip.
