how to remove/replace the steering stem lock?
- vict182
16 Nov 2009 07:52
As the title says
The bike is a 77kz650 b1
i'm about to reinstall the triple tree on my repainted frame. i have a new steering lock with key and i want to replace the old one which is currently in place.
how do i remove that lock from the frame?
in the workshop manual that part doesn't exist.
thanks
thanks
Re: how to remove/replace the steering stem lock?
16 Nov 2009 09:07
On Z1 and KZ900, I vaguely recall a small allen screw holding the lock cylinder in position.
Good Luck!
Good Luck!
- rstnick
16 Nov 2009 10:31
All that holds it in is the cap.
The cap is held on by what the parts diagram calls a tapping screw, which I believe is just knocked into the frame.
You should be able to pry the srcew out, removing the cap and then the lock will come out.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- gane
18 Nov 2009 18:26
Vic, It's been years, But I seem to remember that lower stem locks were retained w/set screws, AND, in order to remove, key needed to be installed and in "unlock" to remove. luck G
[img][/img] 1977 KZ1000A1
