120/90 versus 110/90
  • jklcycles
  • jklcycles's Avatar Topic Author
  • Avondale, AZ
07 Nov 2009 14:54
#331982
The specs call for a 110/90-18 rear tire, but I like the 120/90-18 because it is bigger. Any comments? My bike already handles like crap and I will scrap the bigger tire idea if it will further degrade the handling. Anyone know the pro and cons of going bigger on the rear tire?
1975 Z1-B. Current project.
1977 KZ1000. Future project.
  • Kawickrice
  • Kawickrice's Avatar
Re: 120/90 versus 110/90
07 Nov 2009 15:00 - 07 Nov 2009 15:02
#331986
I am running a 120/90 18 on my Z1 and have plenty of room before hitting chain or swingarm. You shouldn't have a problem at all. If the rim was wider I could go bigger before rubbing the tire
These bikes don't handle like a modern bike but going up a size or two wont hurt anything
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Last edit: 07 Nov 2009 15:02 by Kawickrice.
  • dragnkaw1428
  • dragnkaw1428's Avatar
07 Nov 2009 15:37
#331992
I run a 130 80 18 on my 77 1000. Have about a half an inch between the tire and the chain.
Andy
  • StreetfighterKz
  • StreetfighterKz's Avatar
  • Away
07 Nov 2009 17:22
#332019
You can search this as I know its been covered many, many times before but short answer....
The wider the tire is on the same width rim, the more rounder the profile becomes and the less contact patch you will have.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • RonKZ650
  • RonKZ650's Avatar
07 Nov 2009 17:27
#332020
Where do the specs call for a 110/90-18? Nowhere I've ever read. 4.00-18 is stock and no that is *not* a 110/90-18, not even close. Run a 120/90-18 for all practical purposes, but it will be too wide for the rim. Run a 130/90-18 and it is way to big for the rim. Here's pretty much the rundown on tires.
110/90-18-basically correct width, but low profile=reject
120/90-18-basically the right diameter but too wide=usable, but it isn't perfect for the wheel size.
130/90-18-much too wide for 2.15" wheel=reject
4.00-18-correct tire that works and looks correct-usable
  • dragnkaw1428
07 Nov 2009 17:55
#332037
I run a 130 80 18 not a 130 90 18
Andy
07 Nov 2009 18:31
#332044
I've run 130's and 120's on my KZ650C1. The 130's are ok (hard as hell to mount), but I prefer the 120 as it doesn't distort the profile. Forget 110, you may as well stick a bicycle tire on it. Ed
  • RonKZ650
  • RonKZ650's Avatar
07 Nov 2009 19:55
#332062
Don't matter if it's a 130/90-18 or a 130/20-18. 130 is still too wide to work with a 2.15" rim.:) I've run 120/90-18 for 200,000 miles or more, 130/90-18 a couple times=reject, 110/90-18 once=major reject. Stay 4.00-18 or if absolutely can't stand staying stock, stay 120/90-18 but still too wide for a 2.15" wheel. I have nothing against wide tires, get a 2.5"-3" wheel and go to town, but 2.15" no good trying to go wide.
  • jklcycles
  • Avondale, AZ
08 Nov 2009 10:13
#332123
Thanks for the feedback. I will go with 120/90-18 as that seems to be the consensus. And I like the look of a fatter tire.
