77 650-B1 to 79 650-D3 Frame Swap Project
- PLUMMEN
Re: 77 650-B1 to 79 650-D3 Frame Swap Project
08 Dec 2009 08:59
Kawickrice wrote:
much easier in my experiance ,removing exhuast studs before hand also helpsPLUMMEN wrote:remember to lay motor on its side then drop frame down over it to install,much easier.
Is that really easier? I usually put a milk crate or bucket next to it then straddle the frame and manhandle it. That is how I have always done the 900. If it is the easier way I might try it. What is the dead weight difference between the 900 vs the 650, the 650 seems like childs play compared to the 900. But I guess age will dictate this one.
- anarki650
08 Dec 2009 09:11
I found both those gauges for you. Will keep my eyes open for some pegs for you. I've got a couple of D frames in my garage, not sure if there are pegs on them though... If I don't have them I'll ask around and see if I can't come up with some for you.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Omaha NE
- Kawickrice
08 Dec 2009 11:03
anarki650 wrote:
I did not forget about you. I will get up with you soon. Still making a list.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Kawickrice
11 Dec 2009 08:02
What is the easy way to get the fork lock cylinder out without destroying it?
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
11 Dec 2009 09:29 - 11 Dec 2009 09:33
Kawickrice wrote:
On Z1 and KZ900, it's held in position with a small set screw (maybe allen head type).
Vaguely recall the set screw being accessible when handlebars are turned opposite of "lock" position.
Good Luck!
Good Luck!
Last edit: 11 Dec 2009 09:33 by Patton.
- Kawickrice
11 Dec 2009 16:29
That would make sense to me but I see nothing as far as a set screw on the 650 frame
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- kawsakiman
12 Dec 2009 17:53
did you get the footpegs yet or do i have to go look in the garage to see if i saved them?
- Kawickrice
12 Dec 2009 18:52
kawsakiman wrote:
No I still do not have footpegs. Do you think you still have them?
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Kawickrice
14 Dec 2009 19:42
I have made a little progress in the past few days. I had to put a water pump on my Dodge truck in between working on the bike. Right now I am in the cleaning and degunking stages which takes time, is greasy, and the progress is not showing yet, but will be soon.
The motor is out of the frame and ready for some attention
This is a bag of soda I bought at Harbour Freight for blasting the motor and misc parts. 50# bag of Arm and Hammer baking soda
Here is my blasting equipment I will be using, sand for the frame and the steel parts and baking soda for the aluminum, I will also be polishing the motor covers,fork legs etc.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- kawsakiman
14 Dec 2009 21:02
i'll look as soon as i can for you.
i knew i was giving that frame to a member who would go balls out to get his bike done.
i'm happy to see you making progress.
btw, i got the card today.thanks!
looking forward to more pictures of your build.
- Kawickrice
15 Dec 2009 05:39
The body work is in great shape so a cleaning is all that is needed. My tank is in a little worse shape, my ex wife beat some big dents in it with a big stick that I will be trying the heatgun and cold co2 to pop it back the best I can. (I am glad I got rid of the bitch I only wish I would have done it sooner.
Here is the rear rim before polishing. Its in rough shape but will clean up nice
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Kawickrice
16 Dec 2009 17:56
While I was waiting for the tapered roller bearings to arrive from Z1 Enterprises I had some time for a little polishing and cleaning. The purpose of this project is to get the bike clean and road worthy, It is not a build but rather a swap of parts so the polishing will not be "Show Quality" but rather a cleaning with some attention.
Any project needs to have some tunes but polishing it is mandatory because polishing is boring and tedious.
This is what I have been using to do the polishing. I do not have a polisher that resembles a bench grinder with extended shafts. With a little elbow grease and patience it works nice
Here is the fork legs. One has been polished and the other is what they looked like when I started
This is the fork tube and rear brake. Not a bad reflection for the time spent
This is how far I have gone with some more to go.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
