second post, suspension upgrade ?????
- Black KZ1000
- 1978 KZ1000,1974 bmw R90/6, 1977 xt 500 flattrcker
05 Nov 2009 14:59
Hello thanks for the welcome. I'm building a 1978 KZ1000 and want to upgrade the suspension. I've used the search function extensively and this is what I've arrived at. 1. a GS1100 swingarm,I like the idea of 2 more inches of wheelbase,a weight savings and a bigger tire. 2. Kosman frame brace kit and motor mount kit. 3. This is where I get confused, there are so many options and these options consist of newer bikes that I'm unfamiliar with,my head is spinning. What is an easy close to bolt on upgrade for the front, dual discs,inverted forks etc. I'm leaning toward ZX9 or thereabouts. Any input will be greatly appreciated. Thanks Black KZ1000
- thompsonmx100
Re: second post, suspension upgrade ?????
05 Nov 2009 16:49
Hello sir welcome to the site. There are many options for frontends. The zx7/9 frontend seem to be pretty popular. I put a zx 7 on my 85 gpz750. No matter what frontend you choose you have to swap stems. As most new frontend have much larger stems. You also have to keep in mind the gauge and steering stops.
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- timebomb33
05 Nov 2009 17:12
irishwill has a few sets of conversion triple trees complete for late model gsxr 1000 front suspension. they are really well built and a bolt on situation.
I THINK MY POWERBAND BROKE
- dragnkaw1428
05 Nov 2009 17:37
What wheel and what size tire could you use with a GS1100 swingarm?
Andy
- anarki650
05 Nov 2009 18:40
Black KZ1000 wrote:
Not sure if the stem size is the same between the kz1000 and kz650 but if they are you can pretty easily swap in a front end from a mid 90's zx6. The stem is the exact diameter and length as the kz650. The bearings/races are the only changes necessary, and that's only because the zx6 uses a roller type bearing instead of the antiquated fall out balls that the kz's use stock.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Omaha NE
- timebomb33
05 Nov 2009 19:50
a freind of mine uses a 90 gsxr 1100 wheel and runs a 160 tire on his 82 katana. i use a 4.25 sun rim with a 5.5" mickey thompson on my little drag bike.
- PLUMMEN
05 Nov 2009 20:05
a rebuilt stock kz1000 frontend will take more abuse than the stock chassis will! :laugh:
- Black KZ1000
06 Nov 2009 15:50
Well I bought ZX9 wheels front and back here locally. So I guess I'm searching for a ZX9 front end. Anything I should know? How involved is the swap? Will a GS1100 swingarm work with the ZX9 rear wheel? Thanks Black KZ1000
