Want duel rotor front wheel, which will interchan?
- warchild69
03 Nov 2009 16:23
Hey there guys, I noticed that in my repair manual that some of the Kz bikes came with duel caliper and rotors for the front wheel.... Anyone know which will interchange to my 1983 Kz550 LTD C-4????? I notice that this bike really does not have that much stopping power that im used too with my old ZX-6 bikes had.... would be nice to "upgrade" the brakes!.... Thanks guys!
1983 Kz550 LTD C-4
- warchild69
Re: Want duel rotor front wheel, which will interchan?
04 Nov 2009 12:27
anyone knows which duel rotor wheel will fit my 1983 kz500?...
1983 Kz550 LTD C-4
- Kawickrice
04 Nov 2009 13:15
Can You post a pic of the wheel you have on there now
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Kawickrice
04 Nov 2009 13:18
Keep in mind you will need to change out the master cylinder also. The dual disk caliper is not the same as the single disk caliper
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- JMKZHI
04 Nov 2009 14:18
I don't believe his stock wheel will accept a brake disk on the other side, so he's going to need a front wheel & disks from another model, and matching forks may be needed as well, since dual brake disks are typically smaller in diameter & therefore the calipers are located lower on the forks.
Maybe a GPz550. And perhaps a KZ750-4.
You can cross-reference the parts at Kawasaki.com to get an idea of what might work.
- Locozuna
04 Nov 2009 14:38
Also, the double rotors were thinner to reduce unsprung weight. Not really cut and dry but possible.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- warchild69
04 Nov 2009 20:03
I will see about getting some photos up... but it is a stock wheel, i know for a fact i can not use this wheel.... just dont know what wheel i do need..... my forks have a caliper mount on both sides.... but only one on there now!... will see about getting some photos up tomorrow... thanks guys!
1983 Kz550 LTD C-4
- tooocool49723
04 Nov 2009 20:07
another option would be to just get the whole front end from a dual rotor bike. Probably save some wrenching time too, just on/off with the forks and MC.
'82 KZ550 "Project"
First bike, 30k miles
Ann Arbor, Mi
Ann Arbor, Mi
- warchild69
05 Nov 2009 19:57
I checked all the part #'s for a 83 kz750 and every thing has the same #'s excepy the wheel itself!.... so it shoul fit.... will be getting one this week!
1983 Kz550 LTD C-4
- cafekz750
06 Nov 2009 14:14
I have front rim/dual rotors/brake pads/calipers/master cylinder and lines from an '82 KZ750H3 LTD that is destined for eBay. If you have any interest, pm me.
1981 KZ750H2 - V&H 4-1 pipe, pods, jetted, clubmans, homebrew rearsets, 18" rear wheel and more.
Parting out a 1982 KZ750H3 to fund future projects
2 other non-Kawasaki motorcycles
- warchild69
07 Nov 2009 07:14
Pm Sent!
1983 Kz550 LTD C-4
- loudhvx
07 Nov 2009 09:49 - 07 Nov 2009 09:52
Check the numbers on the disk brake rotors. I've been through this on a 550 and it was a headache.
As it turns out, the 550 LTD forks have mountings for dual calipers, but the mounting points are a little farther away from the axle than on a true dual disk fork. What this means is caliper and brake pads will not line up properly with the disk, because the true dual-disk rotors are slightly smaller in thickness and diameter.
In order to put a dual disk wheel on a U.S. model LTD 550, you would also need the forks from a dual disk model. In the early 1980's, this means you have to use Gpz 550 forks and wheel.
Other countries got some LTD's and Standards with dual disks, but in the U.S. it was only the GPZ (550D and 550H).
Another factor to juggle is that the D model gpz had larger fork diameters than the later H model gpz. (The later gpz used thicker walled tubing).
End result is that I have one LTD fork leg I can't use on my GPZ's even though it almost looks identical to a gpz fork leg.
I can't say what differences the 750 line will have. If the dual 750 rotors are the same part number as your single 550 rotor, then I'd say it should work as long as the fork spacing is the same and axle parts are the same etc.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 07 Nov 2009 09:52 by loudhvx.
