1983 LTD C-4... sprocket questions.....
- warchild69
02 Nov 2009 19:46 - 02 Nov 2009 19:47
Hello there guys, This is my first post... I have owned many ZX's in the past but this is my first KZ!... I bought this bike broken... org owner put on a new chain, did not get the masterlink set correctly and the chain came un done @ 5-10mph.... cracking the gear cover under the front sprocket, shearing the clutch pushrod and bending the shift shaft...
I have all that fixed now... and put the same chain back on, as a temp only.... it runs great... I just dont trust the org setup and want to buy all new.... It has a 16 tooth front, and a 36 tooth rear... 530 chain @ 100 links.... Question is... Is there a place i can find another 36 tooth rear as all i seem to be able to find is 38-42???... also, will i notice that much of a difference if i just replace it with a 38 tooth?..... I am wanting to replace the front as well..... is there a certain combo that i should be looking for.... the gearing always confuses me!...:blink: . I like the way it is now with the 16/36 how would i work it out to have the same gearing if i had to do to a 38 or so rear?...
Thanks a bunch guys and hope to one day be able to help in return!, Kelly
1983 Kz550 LTD C-4
Last edit: 02 Nov 2009 19:47 by warchild69.
- Iron Duke
- what are you rebelling against?
Re: 1983 LTD C-4... sprocket questions.....
03 Nov 2009 01:04
Warchild, you didn't tell us for what machine we are talking about it sounds like a 550cc but could be other model.If you have a 550 16/40 is original size sprocket I believe, Z-1 enterprises should be able to help you,or send you in right direction. and welcome to KZR nation.the invasion continues regards Duke
1982 KZ550 LTD C-3
1979 XS1100 F Yamaha
- warchild69
03 Nov 2009 14:35 - 03 Nov 2009 15:46
Yeap... Kz550 C4.... sorry about that!.... Thanks, I went a head and ordered a new set today. Should be here on Friday... Thanks guys!
1983 Kz550 LTD C-4
Last edit: 03 Nov 2009 15:46 by warchild69.
