front axle ends -threads uneven-moving?
  • trianglelaguna
  • trianglelaguna's Avatar Topic Author
01 Nov 2009 08:12 - 01 Nov 2009 08:16
#330840
i have reset my space/threads reveal to be even when i'm working on the wheel -tire-ect....and i notice it after a while that the axle has worked back to be recessed on the right side and poking out on the left a thread or so......in the blow up below the end nut spacers that clamp into the fork yoke keeps is labeled #1 -lower right of pic...they are the ones in question.....
anyone ever seen this rotation and movement and any ideas of the cause/fix.....
i don't remember my bikes back in the day doing this as a regular thing.....
they don't change enough to warrant right away re-setting ...but it is not a great feeling to see that the axle rod has threaded it's way too the left again..
also it seems to stay consistant once it scoots back over a tad out...
thanks craig
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Last edit: 01 Nov 2009 08:16 by trianglelaguna.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: front axle ends -threads uneven-moving?
01 Nov 2009 08:16
#330842
you need to use some blue locktite on ALL of your friend end parts B)
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
01 Nov 2009 09:13
#330852
Absolutely, a must. And proper torque via manual.
This thing only has two wheels... :blink:
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • PLUMMEN
  • PLUMMEN's Avatar
01 Nov 2009 11:03
#330882
if all else fails use some of amis clear finger nail polish,it works in a pinch ya cheap bastard! :laugh:
  • bountyhunter
  • bountyhunter's Avatar
01 Nov 2009 13:26
#330917
The rest of us cheapskates buy our blue Loctite at Harbor Freight tools. They sell it under their label for about $2 for three little bottles. It's exactly the same stuff.
  • PLUMMEN
  • PLUMMEN's Avatar
01 Nov 2009 17:24
#330948
i dont think the axle can physically fall out since the threads will bottem out before it goes too far,but its still nice to know all the parts on your bike are nice and tight! B)
  • trianglelaguna
01 Nov 2009 17:51
#330951
yeah i guees lock tight is an obvious easy way to end the threads from heading out to the left/rotation of the axle.....i just wondered too if anyone has seen this /is it common /does it have anything to do with having my single disk on the left side / a bearing that bites for a flash under hard loads ect....
locktight on the next teardown for sure....the way the thing is running it'll be going onto the stand in december anyway......oh and plummen....please don't waste your nail polish....save it for saturday nights at the blue oyster.....and your open toe heels...
1976 KZ900
2003 ZX12R
2007 FZ1000
  • PLUMMEN
  • PLUMMEN's Avatar
01 Nov 2009 18:02
#330952
ill see ya there,ill wear the blue dress you love so much! :woohoo:
  • Bluemeanie
  • Bluemeanie's Avatar
02 Nov 2009 05:50
#331049
That's really odd. Once you tightend down the bottom clamps (gap at rear!) they (axle also) can't move. Would take apart and inspect the threads to make sure you have good thread depth. Once buttoned up there is no way it should even be able to move! :S
  • Locozuna
  • Locozuna's Avatar
02 Nov 2009 06:07
#331060
Had same thing on the 900 AND the 650. Like was said loctite and good to go. ;)
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • trianglelaguna
02 Nov 2009 06:19
#331065
the blue dress adds a few pounds and makes you look trashy......wear the sassoon jeans
1976 KZ900
2003 ZX12R
2007 FZ1000
