Another triple tree question
- Ituen
- Rider
27 Oct 2009 06:06
Has anyone here had their factory triple tree modified for newer forks, i.e. 00-08 ZX6R forks?
1982 KZ750 E
Kawasaki Rider
Kawasaki Rider
- Old Man Rock
Re: Another triple tree question
27 Oct 2009 07:01
ZX6 fork tubes are 50mm in dimension, truly would be no safe way to accomplish on KZ tree... easier to just fab up a coupler for KZ steering stem into ZX trees....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- kzr750r1
27 Oct 2009 08:46
Agreed with OMR...
There would not be enough of them to hold the 50mm on even the bottom yoke, let alone the top.
Just be sure converting a new tree to remember the steering stops. Keep from denting your tank.
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
- kano
- Not Another Bloody Limey!
27 Oct 2009 09:42
thought i'd chime in what ive done.
a couple of yrs ago i put a set of 40 mm gpz1000r (86) forks on my bike,
i was able to open up stock triple trees 3mm from 37 to 40 mm.
however there isn't enough metal there to go much bigger.
so when i came to putting a busa front end on,
i had a set of 1 off custom tree's made in Canada.
I'd give you his contact info but i havn't been able to get a reply from him in 6mths sorry. :S
all done! :ohmy:
More pic's here: kano's custom tree's
all done! :ohmy:
- Ituen
- Rider
29 Oct 2009 16:29 - 04 Nov 2009 16:53
You guys are correct. I just talked to the shop doing the work on my triple tree. It's going to be a custom triple tree with the steering stops for $600. Anyone know someone that can do it cheaper?
1982 KZ750 E
Kawasaki Rider
Kawasaki Rider
Last edit: 04 Nov 2009 16:53 by Ituen.
- kzr750r1
05 Nov 2009 08:47
That's a pretty fair price. If the quality is up there.
- Mark Wing
05 Nov 2009 17:58
I would think you can adapt your zx6 tree by changing the stem cheaper than $600.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- Ituen
- Rider
06 Nov 2009 00:11
I don't have a ZX6R tree, but I'm thinking about buying one now.
1982 KZ750 E
Kawasaki Rider
Kawasaki Rider
- Old Man Rock
06 Nov 2009 04:04
Are you also planning on a rear change as well?
Reasoning, front and rears work together for a smooth ride and suspension not to mention safety here....
Also, due to the width of a ZX6 front, I had to relocate my tank and seat back an inch for turning radius of the front otherwise the fork tubes would hit the tank...
Do some research before you get going on this matter for this a considerable amount of work to accomplish...
Is it worth it, oh hell yes but it is work just the same and there's a couple of extremely important issues to deal with to get it all to work correctly... i.e. no high speed wobbles or tank slappers....
Maybe this will help in providing you some insight in what you're facing in fabrications/modifications....
OMR
Front:
kzrider.com/index.php?option=com_docman&...d&gid=431&Itemid=108
Swingarm:
kzrider.com/index.php?option=com_docman&...d&gid=430&Itemid=108
OMR
Front:
Swingarm:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Ituen
- Rider
07 Nov 2009 03:09
Thanks for the info.
1982 KZ750 E
Kawasaki Rider
Kawasaki Rider
- mark1122
- Keep twisting it
13 Nov 2009 15:18 - 13 Nov 2009 15:22
a member here, Irishwill, can make u a set. do a search for his thread called, Pen's z1.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 13 Nov 2009 15:22 by mark1122.
