Wanted dual front brakes
- pg4827
20 Mar 2006 21:51
I want to change from a single disk front brake to a dual system. Does any one know what parts I need, and possibly have any parts? Or know were a whole kit is for bike listed below.
Edited by The Posting Police (so I can unlock it)
Post edited by: steell, at: 2006/03/21 22:27
- steell
Re: Wanted dual front brakes
21 Mar 2006 04:07
All you need is another disk, maybe a master cylinder, a caliper, and the splitter with another line.
I suggest 79 or so 650SR rotors as they are thinner than the single disk rotor and drilled.
I have had second thoughts about locking this thread, so I modified the original post so I could unlock it.
Post edited by: steell, at: 2006/03/21 23:29
- steell
21 Mar 2006 20:33
By the way, 650, 750 twin, and I think 77-79 1000, disk rotors are the same diameter and bolt pattern, and the dual disk rotors are thinner (less weight) than the single disk rotors. If you already have a 5/8" master cylinder, then it will work (actually a 1/2" will work also).
I don't know of anyone selling a kit.
- wireman
21 Mar 2006 20:49
allready pm'd him with parts list ,thanks steel
- pg4827
22 Mar 2006 09:05Please Log in or Create an account to join the conversation.
- pg4827
22 Mar 2006 09:26
The mounting holes are 2-3/4" apart on forks. These are 2-1/2" apart. And the spliter has no space for brake light switch.
- pg4827
- wireman
22 Mar 2006 14:17
those dont look like 79 ltd parts to me.ive got dual splitter valve and caliper you need with right bracket.:whistle:
- fixer5000
22 Mar 2006 16:27
that for sure isnt the right splitter. you need one with 4 holes 3 for lines and the other for the switch..looks like this...steve
1978 kz650b pretty much stock
massachusetts
massachusetts
- Shoe48
- Live each day as it is your last
22 Mar 2006 16:49
The parts in the pic use a brake light switch in the lever .. Just change the splitter as wirman says
- ajohnson
23 Sep 2007 22:33
you can also get an inline brake light switch (part of the banjo bolt) i am thinking about doing the same thing. Anyone know which 650/750 models have compatible dual disks?
