KZ440B Front Drum Brake Upgrade/Improvement?
  • pjed
  • pjed's Avatar Topic Author
26 Oct 2009 15:48
#329766
I'd like to improve the performance of the front drum brake on my 80' KZ440B. What kind of upgrades are there for type of brake? I'm new to drums.
1976 KZ400 D3
2008 Kawasaki Ninja 250 (sold)
2005 Kawasaki ZX6RR (sold)
2013 Harley Davidson 883 Iron
  • PLUMMEN
  • PLUMMEN's Avatar
Re: KZ440B Front Drum Brake Upgrade/Improvement?
26 Oct 2009 16:20
#329768
id swap out to disc brake front end myself,drum brakes are pretty touchy under ideal conditions and pretty much useless under worst conditions in my experiance anyway.id say try kz650 frontend B)
  • pjed
26 Oct 2009 16:24
#329770
I dont' want to go as far as swap the front...I really like the look of the drum. I think it fits in well with the style of the bike.
Are there better pads available like the HH pads for disks? Anyone have experience with them?
1976 KZ400 D3
  • PLUMMEN
  • PLUMMEN's Avatar
26 Oct 2009 16:37
#329776
id say heat is going to be biggest issue with drum ,causing brake fade.another thing you need to remember is your brakes are mechanical versus hydraulic
  • JMKZHI
  • JMKZHI's Avatar
26 Oct 2009 20:07
#329857
The 1980 KZ440-Ltd had a front disk brake.
Choosing function over form might be the thing to do.
27 Oct 2009 09:42
#329928
I had a front drum brake on my old BSA. I found the most effective way to stop the bike in the rain once water got in the drum was to hit a Buick. Effective, but not without its drawbacks. I'd say reconsider a front disk. Ed
  • flht1997
  • flht1997's Avatar
27 Oct 2009 11:55
#329943
make sure that little transfer rod from the front to back shoe is adjusted correctly so the shoes both hit at the same time. have the cable well lubed and adjusted. check the shoes to make sure the friction part is not separating from the backing and you should be good to go. ya guys got to remember this a 370 lbs bike a front drum will get you out of the trouble 26 hp will get you into to (well most cases) and it will look better to boot. if you are having poor brake performance just diassassemble, lube, reassemble and adjust.
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
  • YUKABODOS
  • YUKABODOS's Avatar
27 Oct 2009 12:17 - 27 Oct 2009 12:18
#329946
+1 from me. The drum brakes are too cool to swap out. I guess when you are riding you just need to ride a little proactivly. I love the look of the drum brakes.
Last edit: 27 Oct 2009 12:18 by YUKABODOS.
