another fork question
  • donthekawguy
  • donthekawguy's Avatar Topic Author
20 Oct 2009 03:37
#328538
I built the tool with the 17mm bolt in the end of the tube for the new forks I got and it worked great. the problem I'm having is I can't use those forks so i need to take the stock forks apart but they don't have the "hole" that the bolt head fits into to take them apart. I looked down in there and it looks like it's smooth with no way to stick something in there to hole the guts. My compressor took a dump on me so the broom handle trick won't work. Any other tool I could make that will get the forks apart? I'm going to have them powder coated and put new seals this winter.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
Re: another fork question
20 Oct 2009 09:12
#328572
Here's what I made for my KZ650:
Fork Tool
  • JMKZHI
  • JMKZHI's Avatar
20 Oct 2009 09:38
#328576
The factory tool I've seen has a long T-handle w a metal pyramid on the end. I guess the 4 edges of the pyramid grip the head of the damper rod.
