Help with brake drum
- SteveOrth
12 Oct 2009 22:00
I broke the ear off my drum break, right at the torque bar. What other years or models will work with my 1980 750G Twin?
- JMKZHI
Re: Help with brake drum
13 Oct 2009 06:09
Parts can be cross-referenced at Kawasaki.com.
I find it easiest to search by year only without entering a vin or anything. Once into the diagrams, click the part number, then in the new window click the yellow/black ? icon.
- SteveOrth
13 Oct 2009 06:49
Thanks for the info. It doesn't cross reference with any models. Something has to work in this rim. Any other ideas?
- timebomb33
13 Oct 2009 07:42
can you get it welded back up
I THINK MY POWERBAND BROKE
- Kawickrice
13 Oct 2009 07:45
What size is your drum? I know of two different sizes for sure, but there might be more than two. Post the measurement and you will probably get some help on what might work. If another drum will not work you may have to get a new rear wheel with the correct drum.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- JMKZHI
13 Oct 2009 08:03 - 13 Oct 2009 08:03
A measurement might help, but shouldn't be necessary. Measure the ID of the drum where the panel fits.
Cross-reference all of the other panel assembly parts to see what other bikes will most likely match.
By any chance, is your panel black?
Last edit: 13 Oct 2009 08:03 by JMKZHI.
- Kawickrice
13 Oct 2009 08:06
You might try cross referencing the brake shoes too
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- SteveOrth
13 Oct 2009 10:00
I'll get some measurements. The panel is not black, it is just raw.
13 Oct 2009 10:15
- SteveOrth
13 Oct 2009 14:03
650ed, you are my hero. I saw the grungy one on ebay but missed the clean ones. I think I was searching under drum brake not backing plate.
- SteveOrth
13 Oct 2009 14:07
Just bought the $16 one. Thanks again 650ed. It helps if you know the real name for these parts!
I had a local engineering company heli-arc weld my broken one. It will work until I get the one from ebay.
- JMKZHI
13 Oct 2009 15:23 - 13 Oct 2009 15:29
SteveOrth wrote:
I asked about it being black because that may be why it has a different part number. I'd guess that your damaged panel isn't stock. Not that it matters, but one from any KZ550, 650 or 750-Twin will most likely work. Glad you found one.
PS: If it hasn't been done (or if you don't know the age of them), replace the rear brake shoes. The glue that binds the lining to the shoes can fail over time, leading to a locked rear wheel. Mine locked when rolling the wheel off the center stand - very lucky.
Hee. Kawasaki calls it a rear brake panel.....It helps if you know the real name for these parts!....
Last edit: 13 Oct 2009 15:29 by JMKZHI.
