Rear brake howling question
- kz550krazy
19 Mar 2006 19:20
Just added a new member to our bike family today- a 1987kz305LTD. Purchased for my wife, and is pretty tight other than the speedo doesn't work and the rear brake howls loud when you aplly 90+% pressure. Haven't worked on a rear drum yet, any advice? Probable cause?
- Sandy
- Fly High,Tony
Re: Rear brake howling question
19 Mar 2006 19:26
More than likely,just the shoes are worn out,or there's a lot of brake-dust trapped in there.
Just for the heck of it,see if You can spray in some "Brake-Clean" into the drum...let it dry off and try it out again...if not,You'll have to get in and pull it apart.
1977 KZ1000 A-1
- kz550krazy
- 77KZ650
19 Mar 2006 23:05
I had an old dirt bike with rear drum brakes that were worn out, they made all kinds of noise, metal on metal isnt a good sound!:laugh: If I were you, I would have a look inside just incase, you dont want to ruin the wheel.
Scott
Scott
07 MDP Rookie of the Year
