Help choosing correct size ss brake line.
- oberkfell
10 Oct 2009 08:50 - 10 Oct 2009 08:53
Does anyone know which rear SS brake line I need for a 77 KZ1000A?
And additonal fittings, parts, etc. for a complete replacement.
www.z1enterprises.com/catalog.aspx?pid=KPWB1
Or if anyone has any better choices.
Thanks.
Thanks.
1977 KZ1000-A
Last edit: 10 Oct 2009 08:53 by oberkfell.
- donthekawguy
Re: Help choosing correct size ss brake line.
10 Oct 2009 12:22
z1 has everything you need. Dennis Kirk also has the same parts but they might cost you more.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- MFolks
10 Oct 2009 12:27
I got my 82 GPz 1100's through
www.oldbikebarn.com
The lines are made by HEL
www.helusa.com
is their website.
- Old Man Rock
10 Oct 2009 17:41
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- will61310
10 Oct 2009 18:20
MFolks wrote:
they have a bad habit of taking money and not sending parts, im surprised you actually got them...I got my 82 GPz 1100's through www.oldbikebarn.com The lines are made by HEL www.helusa.com is their website.
...1980 LTD 1000...
- KYKZ1100
10 Oct 2009 19:03
I replaced all my brake lines with the SS lines from Z1. The Kawasaki parts diagram showed the length in mm and I just bought the next size up in inches for each line, after subtracting 3 inches (I believe) for the fittings. My only word of caution is when I first bought the ones for the front I went down .8 inches from the stock length (580mm = 22.8 inches) and they were too short, so I ended up replacing them with ones that were one inch longer. That was a little bit of an expensive lesson, but if anyone needs two brand new, installed for a week or so, 19" SS lines, let me know.
1981 KZ1100A1 Shaft
2007 BMW R1200R
2007 BMW R1200R
- oberkfell
10 Oct 2009 19:47
Are they the correct fit for the rear brake line on a 77kz1000?:laugh:
1977 KZ1000-A
- KYKZ1100
10 Oct 2009 21:28
I doubt it - I think my rear brake line was only 13" plus connectors. The Kawasaki parts diagram doesn't show the length of the rear line. You might just measure from the middle of one banjo bolt to the other and subtract 3" for the fittings to figure out what size to order.
1981 KZ1100A1 Shaft
2007 BMW R1200R
2007 BMW R1200R
- oberkfell
10 Oct 2009 22:16
Thanks for the help.
I know my 30 year old line broke down over time causing my brakes to lock up. I'm guessing the SS will hold up better.
Maybe, I should go the cheap route and just replace it with a NOS part from Z1.
1977 KZ1000-A
- kzr750r1
11 Oct 2009 06:36 - 11 Oct 2009 06:37
You can also make your own with Goodridge parts catalog. I went with stainless fittings and braided hose. Coverd the hose with clear shrinktube. Fittings can be reused so it's a bit of an investment up front.
www.goodridge.net/
Catalog PDF is available for download. Store is closed for some reason.
Good parts though.
www.goodridge.net/
Good parts though.
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
Last edit: 11 Oct 2009 06:37 by kzr750r1.
