Broken FootPeg Bolt - Will it Twist Off? (Pic)
  • skippr76KZ
  • skippr76KZ's Avatar Topic Author
19 Mar 2006 17:41
#32629
Just noticed a booboo on the frame prep & powdercoat job. One of the two bolts for the leftside footpeg holder is broken (& powdercoated). Should this thing just twist off? Perhaps with the prep & powdercoat it is seized in there. What would you recommend? Cut it off and drill it out?
1976 KZ900LTD Fully Restored
2000 Vulcan FI Classic
1998 Ducati ST2, Gone
  • oldcuda68
  • oldcuda68's Avatar
Re: Broken FootPeg Bolt - Will it Twist Off? (Pic)
19 Mar 2006 17:46
#32631
I had exactly the same thing happen. There is a nut on the back. You remove the nut and unthread the stud out of the frame. I used a pair vise grips and it came right out. I then cut the head of a bolt off, then welded the threads on to the stud. Worked like a charm.
Mark
1980 KZ750 LTD
1984 Honda GL1200 Interstate
Too many other toys to mention
  • wireman
  • wireman's Avatar
19 Mar 2006 18:01
#32638
exactly,problem solved!goodluck,happy wrenching!
  • skippr76KZ
19 Mar 2006 18:56
#32658
Excellent! Thanks guys.
