17x3 or 17x3.5
- rob220
17x3 or 17x3.5
08 Oct 2009 12:34
would there be that much of a difference between a 17x3 with stock forks or a 17x3.5 with upside down forks?I have a 17x3.5 but no upside down forks.i have stock forks but no 17x3 so either way i still have to buy some parts.it probably will be easier to buy the rim but will the handling on the stock forks be that much different?
1975z1 w 80 front end
1075kit
29 mikuni smooth bores
vance comp 4n1 header
stretched 6 inches w/double clubfoot swingarm
suzuki tl1000 rim
1075kit
suzuki tl1000 rim
- TeK9iNe
- What did you do!?!
Re: 17x3 or 17x3.5
08 Oct 2009 14:01
It really depends on the springs and thier respective rates that are used in those shocks. Plus the amount of oil in them.
I'm sure you can tune either ones to be better than origional with a little work.
Do what you like!
Do what you like!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- thompsonmx100
Re: 17x3 or 17x3.5
08 Oct 2009 15:30
You probably wont have much difference between a 3 inch or 3.5 inch wheel. forks on the other hand big difference. I would be more concerned about the forks than the size of the wheel. just my .02
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- rob220
Re: 17x3 or 17x3.5
08 Oct 2009 18:55
thanks thats what i was asking about the whole set up not just the rim.the title could be misleading.I have never felt the upside down forks set up.do you notice a big diff between that and say more of a stock set with the x3.i have a set tl 1000 tubes but no trip tree.if it is a big diff. than i will get a tree.if not i will leave my forks and just buy a katana wheel for now.im kinda torn between the 2 looks i like the beefy look up front, but i love the stock look.so i may let the handling decide.
1075kit
suzuki tl1000 rim
1075kit
suzuki tl1000 rim
- timebomb33
Re: 17x3 or 17x3.5
08 Oct 2009 21:28
your bike has a pretty healthy rake to it from the look i get with your pictures i'd probably stick to the stock front as it will never be a real handler it will always be a looker not a handler by. by the way the rake your has look's alot like mine on both of my drag bikes between 7 and 10 degrees
I THINK MY POWERBAND BROKE
- rob220
Re: 17x3 or 17x3.5
09 Oct 2009 00:08
yup you right i didnt think about the rake.i still may go with the upside down for the beef look but i will wait.im in the process of changing the back to a 200mm tire and something about skinny forks up front in my mind is not sitting right(looks wise)
1075kit
suzuki tl1000 rim
1075kit
suzuki tl1000 rim
- rob220
Re: 17x3 or 17x3.5
09 Oct 2009 00:08
1075kit
suzuki tl1000 rim
1075kit
suzuki tl1000 rim
- rob220
Re: 17x3 or 17x3.5
09 Oct 2009 00:13
my bad heres the back
still waiting on my axel but the back i think
will look sweet the front i dont know
1075kit
suzuki tl1000 rim
1075kit
suzuki tl1000 rim
Re: 17x3 or 17x3.5
09 Oct 2009 07:27
Maybe I'm missin something here, but why not just bolt together the wheel and forks you already have and get on down the road?
- rob220
Re: 17x3 or 17x3.5
09 Oct 2009 11:51
TexasKZ wrote:
i dont wanna ride 1 mag 1 spoke i wanna match.the rims i have the front is a 3.5 and wont fit stock forks.i had heard i could bolt the 3.5 with but no fender(dont know if thats true)so if i wanna match i gotta come up with a combo thats suitable for me.im not against stock forks but i dont have the mag to fit so i have to get 1.
1075kit
suzuki tl1000 rim
1075kit
suzuki tl1000 rim
- rob220
Re: 17x3 or 17x3.5
09 Oct 2009 11:56
its almost down time so im not in a rush to get on the road.i still gotta do motor work so no rush.time to part search and get my plan together so i will be ready early next year
1075kit
suzuki tl1000 rim
1075kit
suzuki tl1000 rim
- thompsonmx100
Re: 17x3 or 17x3.5
09 Oct 2009 14:48
The beefier upside down forks would balance the looks of the bike better. But be careful as most upside down forks are shorter. and with the rake you have you might be lacking in the ground clearance department.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
