How often do you oil your chain?
  • kzrider4life
  • kzrider4life's Avatar
Re: How often do you oil your chain?
27 Sep 2009 17:42
#324359
Yeah the carwash is good for cleaning a chain long as you lube it after. i do that now and then:P
Current bike..1977 kz1000 1075cc kit,dyna everything,lotsa chrome,kerker pipe.
  • RonKZ650
  • RonKZ650's Avatar
27 Sep 2009 18:13
#324378
Look at the rollers. If they are dry and shiney It's time to lube. Mileage to get to this point varies greatly. If it's clear blue skys 200-300 miles is practical. You'll notice if you ride through any rain or dirt roads the chain will be already in need of lube. I've lubed mine as often as 20 miles under these conditions. I get 60,000 miles out of a chain.
  • jswag5
  • jswag5's Avatar
  • whats the big deal about harley, i prefer 4 cyls!!
27 Sep 2009 18:21
#324380
every tank of gas(about 120 miles for me) i lube it, and evry other i hose it down w/ wd40 and oil it.
82 kz1000p
83 yammie xj750mk bobber
78 honda cx500 standard cafe
RECENT 81 honda goldwing(barn fresh with 15000 on the clock)
if you cant fix it with a hammer and duct tape, get a bigger hammer and more duct tape!!
  • OKC_Kent
  • OKC_Kent's Avatar
27 Sep 2009 19:08
#324392
I do it often enough that I have a very oily rear rim. 150-250 miles, or every week or two, or every other tank of gas, take your pick.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • Locozuna
  • Locozuna's Avatar
27 Sep 2009 19:42
#324397
When it looks dry. I clean it with wd40 about every 4th oil. I change my oil and filters first about end of March, first of July and then about mid September regardless of mileage. Very little riding between Nov and March. Seafoam every other tank of gas. They all sip on a battery tender when not in use.
Top off the Blinkers once a week and rotate the air in my tires every 5 miles. Sometimes I don't even ride my bike...we just cuddle. :blink:
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • JMKZHI
  • JMKZHI's Avatar
27 Sep 2009 20:00
#324400
You might want to check the chain slack & do an adjustment if necessary. To measure I use a wooden folding carpenters ruler taped to a block of wood. Just place the gizmo on the floor w the ruler next to the chain & check as per the manul.
Liquid Wrench Cycle Chain lube seems to be a good lubricant - plus it's cheap & readily available. It goes on wet but kinda dries to a nice film. For cleaning the chain, I saturate it w the same stuff until dripping wet, then wipe it off w a clean cloth. Sometimes I use a cloth dampened w mineral spirits.
  • Bluemeanie
  • Bluemeanie's Avatar
28 Sep 2009 05:55
#324438
Jeez sorry Im new to bikes... I change my oil every 3k miles...
It's all good dude, people here were just surprised at how long you went. As from above, lube your chain with a good quality chain lube about every 300 miles. As far as oil goes, I change my oil about every 1000 mi and change oil filter every other change. :)
  • timebomb33
  • timebomb33's Avatar
28 Sep 2009 07:38
#324448
most summers if i changed the oil every 1000 miles i'd doing it after weekend with oil i usally drop it after 3000 miles and do the filter every second time myself sometimes i'll even wait for the third change before i replace filters
I THINK MY POWERBAND BROKE
  • bountyhunter
  • bountyhunter's Avatar
28 Sep 2009 12:59
#324486
I cured that problem by switching to the Dupont Teflon Multi-Use spray lube in the blue can ($5 at Lowes). It goes on wet but the carrier evaporates and leaves a waxy coating. Way better than the old slimy stuff.
  • trianglelaguna
  • trianglelaguna's Avatar
28 Sep 2009 16:56 - 28 Sep 2009 16:57
#324516
you better be sorry son, now get in your room till dinner and afterwards no t.v and straight to bed mister!!!!!
anyway like he said do it all the time...get where you have the chain adjusted to have about 3/4 to an inch of play on the chain from it's resting spot (while sitting off the stand wheigthed/resting on its wheels)3/4 an inch up and down from it's rested position is enough imo......get that act down then lube and check every other ride till you get a feel for it...the rollers that hit the teeth should always be lubed/greasy and not shiny...better a dirty rim at first than a shitty driveline imo...also some folks adjust em a tad looser...peacelikes2gofast2009 wrote:
650ed wrote:
Are you serious??? Take a look at the Kawasaki manual. It recommends lubing the chain every 300 km (that's about 186 miles). I do mine about every 300 miles and the original chain lasted 36,000 miles and would have gone further but I don't like running parts until they die. I'm on my second chain with about 49,000 miles and my adjuster is only at the 1st mark. I use "Chain Wax." Just curious, how often do you change your oil? Ed
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Last edit: 28 Sep 2009 16:57 by trianglelaguna.
  • TerryK
  • TerryK's Avatar
28 Sep 2009 18:43
#324536
I lube my o-ring chain with WD-40 once or twice a summer. That's all it needs and I have in excess of 10,000km on the chain and sprockets. Good quality o-ring chains don't need internal lubrication as they have it built in from the manufacture. They merely need to be cleaned and lightly lubed (to keep from rusting) once in a while.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • trianglelaguna
28 Sep 2009 18:52
#324537
how does the metal roller get lubed where it contacts the sprocket teeth...just madfe me think the way you stated the recomendation for an o-ring.....non o-ring here for now till the next one.....TerryK wrote:
1976 KZ900
2003 ZX12R
2007 FZ1000
