help with forks on 82 gpz750. bolt spinning
- hipsterdufus
18 Sep 2009 23:06 - 19 Sep 2009 00:39
i pulled the forks and got one done pretty easily, but the second one is giving me trouble. im trying to remove the bolt that goes up into the inner damper. all it does is spin inside the leg and i didnt bother to check what size nut (if there is one) at the bottom.
i might have enough extensions to make it happen
bolt 92001
www.bikebandit.com/houseofmotorcycles/sh...matic/m9936sch425743
bolt 92001
82 gpz750 7k miles, Husqvarna: 04 cr125, 09 TE310
Last edit: 19 Sep 2009 00:39 by hipsterdufus.
- Mcdroid
- Gone Kwackers
Re: help with forks on 82 gpz750. bolt spinning
19 Sep 2009 01:48
Many times you can hit the bottom bolt with an air impact wrench and it will spin free. Since you have one of the legs apart, you'll note the shape of the top bolt of the inner cylinder...it is that bolt you have to stop from spinning in order to loosen the lower bolt. If the air impact doesn't work, you need to find the correct tool to to do so or fabricate the correct tool...and remove the lower bolt manually. Your shop manual should give you the general idea how to do this.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- chance
- Life long biker/
- chance
- Life long biker/
19 Sep 2009 04:01
Notice he sticks a piece of wood to stop the allen bolt fron spinning this is a cheap way without buying a tool for it this works well....
- JMKZHI
19 Sep 2009 07:13 - 19 Sep 2009 07:15
Usually, you can jam a wooden dowel or something into the fork to keep it from spinning. I carved the end of an old rake handle into the shape of a cone using a power miter saw. Then I tap tap tapped it into place & unscrewed the allen bolt.
Or, if the head of the inner cylinder looks like a 12-pt 19mm socket, there are several ways to use a bolt setup as the tool, with the bolt head fitted into the head of the inner cylinder. I now use a left-hand-threaded nut/bolt/ratchet-extension setup (a 1/2" bolt has a 3/4" head which is ~19mm).
Last edit: 19 Sep 2009 07:15 by JMKZHI.
- hipsterdufus
19 Sep 2009 08:45
wow, thanks for all the good replys, lets try the dowel trick first, before a run to ace hardware
thanks !
thanks !
- hipsterdufus
19 Sep 2009 10:44
got it with a broom stick, thx
- chance
- Life long biker/
19 Sep 2009 19:34
Glad you got it nothing to it Huh.. Greetings from Kramerica Industries.
