Chain Length/Size
- paulstanely45
- 1977 KZ650-B
Chain Length/Size
15 Sep 2009 18:28
Hello,
I was wondering about bike chain size/length.
My bike is a 1977KZ650B, which calls for a 530-102 chain.
I bought a 530-110 chain today, and when I counted the links, there were 110 excluding the master link that came in a separate baggy.
When I am shortening my chain, do does it need to be 102 links including the master link, or 102 links not including the master link?
1977 KZ650-B
- bountyhunter
Re: Chain Length/Size
15 Sep 2009 19:30 - 16 Sep 2009 12:08
paulstanely45 wrote:
It's not possible for a "split" (unconnected) chain with no master link to have an even number of links in it. The links are in male-female sets of two, so the master is the even numbered link to be added.
Including the master link.Hello,
Last edit: 16 Sep 2009 12:08 by bountyhunter.
- Johnj
15 Sep 2009 19:44 - 15 Sep 2009 19:47
That would be 102 without the master link. Back off the chain adjusters all the way and push the wheel all the way forward in the swingarm. Check that 102 links will work before you knock that pin out.
Veho vivo - Ago ut veho
Last edit: 15 Sep 2009 19:47 by Johnj.
- Zmoto
15 Sep 2009 20:45
bountyhunter wrote:
That is correct. I'm with Bountyhunter on this one
paulstanely45 wrote:Including the master link.Hello,
- paulstanely45
- 1977 KZ650-B
15 Sep 2009 20:49
After some closer counting the chain has 109 links plus the master link.
My bike calls for 102 links, so I guess I would knock off 8 links and then use the master link for a total of 102 links?
1977 KZ650-B
- bountyhunter
16 Sep 2009 12:10
Correct, but I would fit it by hand before cutting to make sure in case you have a larger sprocket.After some closer counting the chain has 109 links plus the master link.
- Bakes
- Z1 Enterprises Customer Service Guy
- timebomb33
17 Sep 2009 21:39
what i used to do if i had an extended swingarm that i had just put on was take a piece of 1/4 rope and wrap it around the sprockets with the rear axle adjusted where you would need it then mark on the rope how long it was then measure that and divide the size of link that your using 3/4 for a 630 chain for example into that lentgh and you will come up with the amount of links you will need then i take the number and add a couple of extra links just in case.
I THINK MY POWERBAND BROKE
- PLUMMEN
