Brake pads scraping rear disc
- XL777
11 Sep 2009 21:50
I noticed when I rolled the bike into the garage today the rear brake pads were scraping on the disc. I replaced the pads about 1500km ago and this is the first time I have noticed it. Any idea's? Maybe I need to re bleed the line or the cylinder has pushed the pads out too far?
2012 Triumph Bonneville SE black
1978 KZ1000 B2 LTD
Fresh top end rebuild
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
It is easier to say what I haven't replaced then what I have.
I must love this cruel mistress since she hates me
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
- Johnj
Re: Brake pads scraping rear disc
11 Sep 2009 22:14
Does it bind up or just kinda rattle up against?
Veho vivo - Ago ut veho
- bountyhunter
12 Sep 2009 00:17
They are supposed to drag a little. most have the "floating caliper" and one side will rub the disk a little. No sweat unless it's dragging enough to cause binding or noticable drag.
- chance
- Life long biker/
12 Sep 2009 05:12
Your rear rotor may have some warpage....
- Old Man Rock
12 Sep 2009 06:54
"Your rear rotor may have some warpage...."... Yup!
or a caliper that's sticking closed...
Raise the rear and spin the tire.... While observing the rotor from above, warping as in a warped album on a record player?
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- trianglelaguna
12 Sep 2009 09:02
when you changed the pads...did you check to see how far the piston had ended up from the thin pads? did your old pads wear really thin? sometimes the piston get a little grime that keeps it from recessing with the new pads....did you lube the two pins that the active half of the caliper slide on?.....is you brake pedal adjusted to let off the push rod completely?......they drag a bit anyhow and make noise at first if it got wet,misty....ect....then sat and dried.......
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- bountyhunter
12 Sep 2009 13:07
One thing: they will drag if the caliper assembly is sticking on the pins it rides on. had to take them off my wife's car and clean the pins and regrease them because they were dragging a lot.
