z1 needs stretch,wider tire, and disc breaks..HELP
  • 75z1
  • 75z1's Avatar Topic Author
11 Sep 2009 12:28
#320699
Hey guys, I was wondering if anyone has done any projects for extended swing arms...I'm thinkin of maybe going with a spoked harley rim on the back, or even a sport bike wheel.. I have a good idea how to do it. but pictures and advice from someone who has already done this would be amazing
  • 75z1
Re: z1 needs stretch,wider tire, and disc breaks..HELP
11 Sep 2009 12:38 - 11 Sep 2009 12:39
#320705
here is a pic of the bike
Last edit: 11 Sep 2009 12:39 by 75z1.
  • Splandman
  • Splandman's Avatar
11 Sep 2009 13:05
#320706
Look in the projects section on this forum.
Nice bike.
Current Bikes
1980 KZ1000E
  • 75z1
11 Sep 2009 14:12
#320723
Thanks buddy
in the middle of the rebuild
  • z1kzonly
  • z1kzonly's Avatar
11 Sep 2009 15:01
#320773
I started this 9 years ago.
All stock parts modified.
4 inch wide Hog wheel, with 150x80x16 tire.
  • z1kzonly
  • z1kzonly's Avatar
11 Sep 2009 15:06
#320778
here is another pic
  • z1kzonly
  • z1kzonly's Avatar
11 Sep 2009 15:09
#320779
another
  • 75z1
11 Sep 2009 19:02 - 11 Sep 2009 19:03
#320813
thanks alot for the pics, the bike looks amazing.. but your back wheel..I notice its hub..is that just a wider rim laced on to the stock hub??? and how hard was it for the chain alignment with the wider tires..and is your front raked or just lowered
Last edit: 11 Sep 2009 19:03 by 75z1.
  • z1kzonly
  • z1kzonly's Avatar
11 Sep 2009 19:41
#320819
Yes the front end was raked, just cut heated , bent and three gusset plates were tig welded in place.
The swingarm was cut, and steel plugs were cut and put in all 4 sides and tig welded.
It maintains the stock width. the tire is a 150 width.
Buchannon spokes were laced to the stock hub with a 4 inch harley rim.
I have a 3/8" offset on front, and a 3/8" on the back. I used an aluminum rear sprocket with countersunk bolt holes and flatheads tapped into the carrier, for clearence. I think if I used a 530 chain setup, a 180 tire could be used.
This chassis has a 6 inch longer wheel base.
I have steering dampeners mounted on each side.
This is built just for a cruise night bike.
It is a 76, I have a 1015, stock motor freshened up, dual Z1R discs on the front, custom lowered trip tree, which can lower the gauges.
It has a small LTD tank and small front fender.
I reupholstered a stock seat, It is very nice, cost me $200 alone for seat. Check out the rear axle, 2 sided nuts, solid stainless steel, with stainless adjuster plates.
Lean, low and cool, like a drag bike.
I tried to sell it in the past, no one wanted it for 2 grand.
Hope this gives you some ambition and ideas.
  • 75z1
11 Sep 2009 21:32
#320853
I can't explain enough how much i appreciate the information..This is the exact setup i was looking to do..prolly no rake for a while but lowered and stretched, with the harly rim...just didnt know if i could lace the stock hub to it or not...and the fact that i can keep it stock width is awsome too becuase i thought i was going to have to widen the ass a lil bit..and i was kinda wonderin how the chain set up work but i understand it now..Looks like i'm going to have to get the welder out this winter..I wanna do it now bu i literally just got the bike put together and running on monday..I had 2 bikes a blown up one and a wrecked one so i combined them both to make my new baby...oh and who did your seat
