Valve Shim Tool
- Pfaelzer
Valve Shim Tool
10 Sep 2009 10:15
What are you guys using?
I never used the Motion Pro Tool and am wondering if it does the job or if the factory tool is the way to go?
1977 KZ 1000
Queen Creek, Arizona
- roy-b-boy-b
Re: Valve Shim Tool
10 Sep 2009 10:30
Go factory! I have the Motion pro and it will do the job but is a hassle. Roy
- Mcdroid
- Gone Kwackers
Re: Valve Shim Tool
10 Sep 2009 10:54
I second Roy...I have both and no longer use the Motion Pro tool. Once you get the hang of the factory tool...it is very easy to use...of course, the same could probably be said for the Motion Pro tool... :laugh:
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Pfaelzer
Re: Valve Shim Tool
10 Sep 2009 11:01
thx Roy and Mcdroid. I'll go ahead and order the factory tool from Z1E.
1977 KZ 1000
- timebomb33
Re: Valve Shim Tool
10 Sep 2009 11:36
i really like the motion pro tool myself but i guess i have used it so much it's allmost part of me now.
I THINK MY POWERBAND BROKE
Re: Valve Shim Tool
10 Sep 2009 16:43
With the Motion Pro tool, I ignore the "lever" and use only the "batwing" by depressing the bucket with the cam lobe (instead of the lever), then holding the batwing in position to catch the bucket edge while turning the cam lobe away.
After replacing the shim, turn the lobe to depress the bucket and allow removal of the batwing.
Requires a little fiddling to get the knack, but then it's quick and easy with just the batwing.
Good Luck!
Good Luck!
- flht1997
Re: Valve Shim Tool
10 Sep 2009 19:10
What Patton said, except I threw the lever away, it just pissed me off too much but the batwing works well
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
- ArthurGoVroom
- I'd rather ride it than shine it
Re: Valve Shim Tool
10 Sep 2009 20:00
My dad had an old shim changing tool (just like the modern Motion Pro tool), but the "batwing" was long gone, so I ordered a new tool and I used both of the levers together to depress the bucket. I'd slip one between the lobe and shim as far as it'd go and pry to depress the lifter a bit, then insert the other lever and do the same thing, alternating until the bucket is compressed far enough to get the holder in place.
I never used the factory tool, but I suspect it probably works better.
1976 KZ900A4, 4-1 header, rear lowering kit, grab bar removed, still shining and painting parts as time permits
- Kawickrice
Re: Valve Shim Tool
11 Sep 2009 08:14
I use plastic zip ties. Take a zip tie and fold in half and put a small bend at the end then pull out the spark plugs and put the zip tie down in the hole with the cam lobe down to open the valve. Now rotate the motor with a wrench and the zip tie will keep the valve down so you can remove the shim. It works like a charm and is very inexpensive and you can use two hands for shim removal.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- macskz1000m
- MIke McKinney
Re: Valve Shim Tool
12 Sep 2009 06:47
I use a cotter pin removal tool pointy screwdriver with hook works very well because thats what I have in my box but I am sure factory tools work better as they usually do but I might try the zip-tye method next time sounds interesting;)
81 KZ1000 M1CSR,10,500 miles,80 Honda CT110,1,500 miles,2000 HD XLH1200,23,000 miles 99 Vette 100,000 miles coldair intake,borla exaust,predator programer.FUN,FUN,FUN.RIDE HARD,RIDE FAR,RIDE FOREVER.
