Front Shock Oil
  • mzandmz
  • mzandmz's Avatar Topic Author
Front Shock Oil
08 Sep 2009 17:05
#319983
1977 KZ650 needs new shock oil. What weight should I use. I am a 265 pounder abd bike is stock with saddle bags(fake leather).? :dry:
New to Family, 1979 KZ440 LTD
  • timebomb33
  • timebomb33's Avatar
Re: Front Shock Oil
08 Sep 2009 17:24
#319987
20wt fork oil and use the recommended amount. as heavy as you are i'd think about going to a different spring fromprogressive suspension you will need a stiffer spring rate the stock springs have over 30 years on them and also the bike would have been set-up for someone around the the 150-175 lb mark so it may be a bit softly sprung for you.
I THINK MY POWERBAND BROKE
  • bountyhunter
  • bountyhunter's Avatar
Re: Front Shock Oil
08 Sep 2009 19:11
#320024
Stock oil on mine is 15W, I found that to be the best but you could try 20W and see if you like it.
There are definitely some very nice gas charged rear shocks and progressive springs that will help a lot. Check Z1 Enterprises, they used to sell them.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Front Shock Oil
08 Sep 2009 20:53
#320053
here we go again! :laugh: 30w synthetic motor oil B)
  • mzandmz
Re: Front Shock Oil
08 Sep 2009 21:03
#320056
You bet ya.. Again we suffer. OILs well that ends well. Might try the 30winter OIL.
  • TexasKZ
  • TexasKZ's Avatar
Re: Front Shock Oil
09 Sep 2009 15:23
#320221
Freshly squeezed castor bean oil, anyone? ;)
  • trianglelaguna
  • trianglelaguna's Avatar
Re: Front Shock Oil
09 Sep 2009 15:34
#320229
try putting some 1x 1 pvc spacers on top of the spring and replacing the fork cap when you change the oil.......gives the front some pre-load...on mine it wakes up the front a tad...combined with air caps,prog springs,10 w oil,and new tire ,correct pressure....good luck
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
