what will fit
  • fat z
  • fat z's Avatar Topic Author
what will fit
07 Sep 2009 15:43
#319727
Quick question, actually 2,what newer frontend (usd fork) will fit on a 76 kz900 with minimal work, as i've been told a zx7 frontend and a tl1000 front end will go with just a bearing swap. Question 2,how wide of a rear wheel will go in a gs1100 swing arm,and what kind of modifications will need to be made to the arm to fit the wheel. like a ninja or gsxr wheel.
  • TerryK
  • TerryK's Avatar
Re: what will fit
07 Sep 2009 19:29
#319769
You'll get lots of answers here. Tons of guys have done this conversion. If you are going to use wheels from a gsxr etc, why not use the matching swingarm so it saves you modifying a wheel.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • donthekawguy
  • donthekawguy's Avatar
Re: what will fit
07 Sep 2009 23:34
#319813
For the rear wheel you will need either spacers made or have the hub cut down. Not sure about the front but if it is a drop in it will be the first time I have heard of it. You will probably need to use the kz stem with the zx7 clamps.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
Re: what will fit
08 Sep 2009 08:12
#319857
You can use pretty much ANY front end with just a stem swap. Take care to buy a complete front end though, or as far as possible, or it can end up costing you more than you thought. That means forks, yokes (triples), handlebars, wheel, brakes, mudguard, wheel spindle with all the spacers etc. Have a think about what you are going to do about the clocks, lights and switchgear too.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
  • fat z
Re: what will fit
08 Sep 2009 08:37
#319863
that was the plan. get the whole frontend and wheels. but i would like to keep my swing arm thats why i was also wondering how wide of a wheel/tire combo i could fit in the gs arm.
