Axle for GS arm?
  • sbulla
  • sbulla's Avatar Topic Author
  • 1980 KZ1000 LTD
Axle for GS arm?
03 Sep 2009 17:24
#318950
In case I get the GS1100e swingarm in shape to install on my '80 KZ1000 LTD, what axle do I need to find that will be long enough and the correct diameter?
I'll be using the stock wheel.
Sonny
Now----
1980 KZ1000 LTD (Kerker 4-1, K&N pods, Dyna gray coils)
Gone but not forgotten----
1966 Honda 305 Superhawk
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
1995 HD Sportster 1200
2000 HD Softail
2002 KLR650
  • TerryK
  • TerryK's Avatar
Re: Axle for GS arm?
03 Sep 2009 18:28 - 03 Sep 2009 19:52
#318958
Sonny
If the axle diameter is the same, the GS one will work. If not, then you'll have to find wheel bearings with the same outside diameter as the KZ, and the same inside diameter as the GS. I had to do this with my 88' Gixxer arm but I ended up having a machinist friend make me a new axle and wheel spacers.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Last edit: 03 Sep 2009 19:52 by TerryK.
  • donthekawguy
  • donthekawguy's Avatar
04 Sep 2009 00:26
#319018
You need to use the gs axle. It is 20mm so you might have to call all balls and order a set. I used a spoke suzuki wheel so I lucked out when it came to bearings.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • toadson
  • toadson's Avatar
04 Sep 2009 10:17
#319072
I used the stock GS arm when I did my swap. Check eBay if you can't find one.
79 KZ1000 LTD. Mikuni VM26 w/ accelerator pump. 4 into 1 header. Stock intake setup. GS1100 Swingarm, My swap thread: kzrider.com/index.php?option=com_kunena&...d=5&id=210872#210872
  • lewisj
  • lewisj's Avatar
04 Sep 2009 11:40
#319088
Be careful on ebay. I ordered two GS 1100 axles and both were too short for the swingarm.. Must have been a difference between the "E" and the other models, or the sellers didn't know what they had.
Good Luck, Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Vance&Hines header/ exhaust
29mm smoothbores w/pods
ZR7S 41mm Front Forks with 17" wheels
  • tachrev
  • tachrev's Avatar
  • Rubber Side Goes Down
04 Sep 2009 11:49
#319091
I've seen posted on here a few times that a KZ1300 axle will work as well.
Build Thread
