help with zx7r forks
- thompsonmx100
02 Sep 2009 17:40
I know a few people have zx7 forks on their bikes and I do too now. I was playing with the preload adjuster and I guess I backed it out too far and it came unhooked from the dampening rod and I dont know how to put it back together. I may just take the things apart and put new seals oil and bushings in them. I thank you in advance for any info.
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: help with zx7r forks
02 Sep 2009 17:53
heres some pics the only thing i can figure is the PO had the jam nuts loose on the dampening rods and thats why it came apart
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
02 Sep 2009 17:54
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
02 Sep 2009 17:54
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
03 Sep 2009 15:07
help noone has rebuilt these forks
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- larrycavan
03 Sep 2009 15:36
thompsonmx100 wrote:
I took mine apart and put new seals and bushing in them. That was a year ago though. 96zx7R
The 7R forks are not all the same.
The adjusters do spin down on the rod...as you already know. I'd have to check the manual for more details on install setup. I have the factory manual for that bike if you need something copied. Holler if you do.
Larry C
Larry C
- thompsonmx100
03 Sep 2009 19:38
thanks Larry. I am just curios as to how you are supposed to push the spring down far enough to thread the cap on. Or if you are supposed to have the forks apart and install it. If you could let me know what it says in the manual. If it is complicated then i may have to do something else. I'm thinking if I take a wrench and press the spring down then with an extra set of hands thread the cap on.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- kano
- Not Another Bloody Limey!
03 Sep 2009 19:48
that's how i did mine,
helps if you can get the load off the front wheel too!
- thompsonmx100
03 Sep 2009 20:02
thanks Kano I have them bottomed out.I think I'm gonna try it tomarrow
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- kano
03 Sep 2009 20:08
just be real careful clean the threads and lightly grease,
i found a socket with a short extension and a rachet works best while doing this helps to sit on the bike/
- thompsonmx100
14 Sep 2009 17:28
thank you for your help guys. I have another question. I think the oil level is low. Could someone tell me what oil to use and how high the oil is supposed to be and where to measure it from. Any info would be appreciated.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
15 Sep 2009 14:47
bump anyone know about the oil in these forks?
1985 gpz750
Kz 650
1985 gpz750
Kz 650
